What did you do to your C3 today?
#3101
Received 3,138 Likes
Got the valve covers back from power coating a while ago and finally finished polishing the fins and got them re-installed.
All the wiring is done and the various coolant and vacuum hoses are back on and I think I'm actually close to starting it up and seeing what new problems I've created
Maybe next weekend
M
Maybe next weekend
M
#3102
Removed the map pocket panel, park brake cover and console so that I could pull back the center gauge cluster bezel. To check the stupid oil pressure gauge, make sure it's still hooked up correctly and not kinked. All was good, ran the car about 5 minutes, idle and rev, gauge seems to be working properly now. The line might have been getting caught between the driver's lower panel and the center gauge bezel causing some weird readings; I used some wire tie to 'help' it stay free before I closed everything back up. Will drive tomorrow and see.
#3103
Received the distributor for my 496 today.
Placed it up on the shelf with everything else.
#3104
#3107
OldCarBum (06-23-2018)
#3111
Got all my old carpet and what was left of the old insulation, it wasn't much...
Almost half done in a evening! Glad I worked on my old foxbody before this car, I wouldn't have had the experience with how many screws and layers of stuff there are in older cars.
#3113
Installed 10" wide wheels in the back and skinnies up front. Replacing the front wheels shaved 80 lbs off the front of the car. Also installed thick tubed half shafts with Spicer u-joints, and installed 4.11 gears.
#3114
Received 3,220 Likes
I got my new gas cap- then modified it to fit-
Take off of a 2018 Dodge Challenger...yes, a MOPAR gas cap.
I just used a heat gun to take off the emblem and turn it 90º
Shdggsdv (08-22-2018)
GregS_72 (06-25-2018)
#3120
Picked up the new MSD 6AL box, MSD coil, coil bracket and distributor gear for my 496.
Ordered the Edelbrock water pump and timing cover today.
That's about it for the motor, except for a few minor items.
Time to move on to the new TKO-600 and conversion kit from auto to manual.
The fun never ends.
