What did you do to your C3 today?
Old 02-04-2019, 02:55 PM
  #3701
Primoz
Primoz's Avatar
2017 C3 of Year Finalist
Nice! Thanks for the tip!
Old 02-04-2019, 06:34 PM
  #3702
74_stingray
74_stingray's Avatar
C3 of Year Finalist (performance mods) 2019
St. Jude Donor '19
Originally Posted by Richard454
I messed with the "Krome Zone" powdercoat from Summit.
My Harbor Freight Gun works great- but the difference between Summit's media and Harbor Freight's - Summit's is about $15 a 1lb more - works a heck of a lot better.
Here's all the hood deck lid hardware-
Richard, the powder coated parts look great.
Eddy
Old 02-04-2019, 06:54 PM
  #3703
Jason Burt
Jason Burt's Avatar
I replaced both trailing arms, strut rods, and put in a composite rear spring this weekend... getting her aligned this week then it's off to the races...well, the neighborhoods
Old 02-04-2019, 09:18 PM
  #3704
kschultz55
kschultz55's Avatar
Default great weekend
Sunday I went to the swap meet in Nashville TN . I found the correct harmonic balancer pulley for the SBC.
this week end I will put the shim kit in the rear railing arms.
Old 02-06-2019, 06:56 AM
  #3705
Primoz
Primoz's Avatar
I repainted the wiper door actuator.
It came out pretty nice!
Old 02-06-2019, 07:06 AM
  #3706
naramlee
naramlee's Avatar
well?
with and how 😋
Old 02-06-2019, 07:24 AM
  #3707
Primoz
Primoz's Avatar
Originally Posted by naramlee
well?
with and how 😋
I cleaned it with a bit of very fine sanding paper. Then used anti rust primer and a very thin coat of paint. I had to re-do it because the first time I sprayed it too much and the paint started to peel and flake.
The second time I sprayed it with very thin layer and it came out nice. But still the paint is quite "fragile" if I can say so. You can scratch it easily.
This is what I used:
The codes of the paint.
Auggievf (02-11-2019)
Old 02-06-2019, 07:26 AM
  #3708
Primoz
Primoz's Avatar
I also removed and cleaned the vapor canister and repainted it with plastic paint.
I used this for the first time and I'm very happy with the results.
Before!
After
again after
this is what I used.
Old 02-06-2019, 09:02 AM
  #3709
74_stingray
St. Jude Donor '19
Primoz, all the paint work looks nice.
Eddy
Old 02-06-2019, 02:27 PM
  #3710
naramlee
naramlee's Avatar
Eddy
yes it does, looks almost like new, good job!
Primoz (02-06-2019)
Old 02-09-2019, 12:46 AM
  #3711
OldCarBum
OldCarBum's Avatar
Received 4,690 Likes on 2,933 Posts
Picked up my ARP main cap bolts and head bolts.
Man, are these things made of solid gold or what?
Old 02-09-2019, 04:07 AM
  #3712
CraigH
CraigH's Avatar
Primoz, that looks so good.
I am going to look for that paint in Australia.
Old 02-09-2019, 04:25 AM
  #3713
Primoz
Primoz's Avatar
These are good quality paints. My friend introduced them to me. They use them at their factory where they produce cabins for Caterpillar. They use the anti rust ones to protect the welds from rusting.
The black paint is also very good. Used it on some parts. Will post a picture of the fan, which I sandblasted and painted it in black.
Old 02-09-2019, 08:25 AM
  #3714
brit vet
brit vet's Avatar
2021 C2 of the Year Finalist - Unmodified
St. Jude Donor '13
sold it. I may have done 500 miles in the '72 in 2 years as my default is always the LT-1. I will replace it, just not sure what era Vette will be the replacement.
It's gone to a good home, or it will at the end of Feb. A little sad but I firmly believe they should be driven and that wasn't happening with this one
Old 02-09-2019, 09:00 AM
  #3715
Primoz
Primoz's Avatar
What a nice pair of Vettes! I mean! WOW! Really! But I do understand the selling part. Don't you agree that these cars work better when they are driven regularly?
brit vet (02-09-2019)
Old 02-10-2019, 06:13 PM
  #3716
Street Rat
Support Corvetteforum!
Street Rat's Avatar
I've been putting this project off for quite a while. I got some tools together to pull the windshield out of my '81.
I was pleasantly surprised that there was only surface rust and no rust holes. Had some problems getting four of the clip retaining screws out. Stripped out screw heads. Now the fun begins.
Craig
Old 02-10-2019, 06:22 PM
  #3717
The Phantom
The Phantom's Avatar
Craig
Lucky, you should buy a Lotto ....
Dave
To What did you do to your C3 today?
Old 02-10-2019, 06:24 PM
  #3718
74_stingray
St. Jude Donor '19
Craig
Looks great! Good luck with the project.
Eddy
Old 02-10-2019, 11:17 PM
  #3719
Primoz
Primoz's Avatar
Craig
Good job Craig! And very important job at that! Keep it up!
Old 02-11-2019, 06:39 AM
  #3720
Street Rat
Street Rat's Avatar
Dave
Yes I should.
Eddy
Thanks Techoca
Thanks Primoz. Lot's more to do.
Quick Reply: What did you do to your C3 today?
