What did you do to your C3 today? - Page 3 - CorvetteForum - Chevrolet Corvette Forum Discussion
Old 01-18-2015, 08:59 PM
  #41
Cool95vette
CF Senior Member
Cool95vette's Avatar
Installed new aluminum radiator and trans cooler with dual electric fans.
Cool95vette is offline
Old 01-18-2015, 09:35 PM
  #42
Wanna be
CF Senior Member
Wanna be's Avatar
I put my 4sp back in today. I took the electric headlight actuators out to get ready for the new vacuum actuators.
Wanna be is offline
Old 01-19-2015, 12:12 AM
  #43
blk79nj
CF Senior Member
blk79nj's Avatar
I took off the carb to adjust the float level. Put it back together and started putting it back on. I looked on the bench, I left out the plastic piece that hold in the float.
So after cursing a little bit, i took it back apart put the piece in. Put it back on the car, and decided to wait till tomorrow to hook it all back up and test drive.
I then came in, and watched a YouTube video on how to adjust the secondary air doors. I think they flop open too soon, so I'm going to tighten up the spring to see if that helps.
blk79nj is offline
Old 01-19-2015, 12:21 AM
  #44
nestor
CF Member
Put the diff back in.
nestor is offline
Old 01-19-2015, 12:29 AM
  #45
Procrastination Racing
CF Senior Member
Procrastination Racing's Avatar
Put gas in it and drove to see the Warbirds.
Now last night, I put a new water pump in it. It must have worked, there is no coolant leaking on the ground.
Procrastination Racing is offline
Old 01-19-2015, 02:02 AM
  #46
doorgunner
Doorgunner's '68 Project
Support Corvetteforum!
doorgunner's Avatar
I attempted............. to install the new-to-me Delco....
but the wiring harness needs lengthening to make dash-work easier in the future........
doorgunner is offline
Old 01-19-2015, 08:27 AM
  #47
donnie1956
CF Senior Member
donnie1956's Avatar
Took the cover off and drove it. Name:  CorvetteTungstenJan15driverside_zps547216cd.jpg
donnie1956 is offline
Old 01-19-2015, 08:50 AM
  #48
Stroh
CF Senior Member
Stroh's Avatar
I walked out to the back yard, pulled up the garage door, pealed back the dust cover, and stared longingly. Then my future stretched out before me and flashed like a strobe light. It was me driving her down a country road in the sun, smiling. Then I was putting her away and wondering why when I hammered the breaks she pulled slightly to the right. My thoughts wandered (as they often do) to contemplating just how difficult it will be to replace the rear two body mounts that have rotted away into a crushed donut-like mass of 70's rubber. How soon will I brave the temps to replace the starter and install the starter heat shield? When will I redo the Retrosound stereo and hideaway amp and speakers tucked up against the roof of the rear? Do I really want to replace the stock hood with a stinger??? Yes, maybe, I don't know.
Then I slammed what was left of my bud light, lowered the door, and trudged back through the snow into the house, pouting the whole way.
Stroh is offline
Old 01-19-2015, 08:59 PM
  #49
Bel
Junior Member
She just sits calmly in the garage. Resting, with her car cover snugged around her shiny and smooth front bumper. I pass by her every morning and then again when returning from work. Sometimes a deliberately brush by her just to give her a sense that I'm there. Before bedtime, I make an excuse to secure the garage side door, but only to reach down, grasp her covered bottom skirt, pull it up just slightly, and take a peak at her beautiful red finish. Sometimes I even brush my hand across her outer fender lip or her beauty rims just to feel the smoothness of her finish.
Come one guys . . . tell me you've never done something like that . . .
Bel is offline
Old 01-19-2015, 09:02 PM
  #50
LS4 PILOT
CF Senior Member
LS4 PILOT's Avatar
Drove ..
Sunny and 60 *F +
More tomorrow.....woo hoo
LS4 PILOT is offline
Old 01-19-2015, 09:16 PM
  #51
Wanna be
CF Senior Member
Wanna be's Avatar
Yep!
Wanna be is offline
Old 01-19-2015, 09:28 PM
  #52
AboveTheLogic
CF Senior Member
AboveTheLogic's Avatar
Never something quite like that, but I've been caught sitting in the car pretending to drive when it is down.
AboveTheLogic is offline
Old 01-20-2015, 12:08 AM
  #53
Kris Tunetso
CF Senior Member
Kris Tunetso's Avatar
Pulled apart the shift console to figure out what was causing the HVAC adjustment wheels to bind. Turns out the whole console was sitting too low on the tunnel. Raised it up to the right height, which wasn't easy, and now the wheels turn smoothly. Also noticed Bubba's aftermarket radio wiring is... messy. Functional, but messy. Will have to clean that up at some point.
Kris Tunetso is offline
Old 01-20-2015, 07:59 AM
  #54
Street Rat
CF Senior Member
Street Rat's Avatar
I put in a Davis Unified Ignition Distributor. I had ordered it for the new engine that I'm building. I decided to try it out in my paltry stock engine for now. I gapped some new plugs to .050, put them in, and set the timing at 12 BTDC. Took her out for some spirited driving with some cheap 87 octane fuel. I have a very slight rattle at WOT but what a difference? My new engine will be running higher octane fuel so everything should be ok.
Street Rat is offline
Old 01-20-2015, 10:51 AM
  #55
U17
CF Senior Member
U17's Avatar
Just taking it out to a lunch with a bunch of other Corvettes ....
U17 is offline
Old 01-20-2015, 11:58 AM
  #56
samdjr74
CF Senior Member
samdjr74's Avatar
Nothing today, still waiting on the last few parts of my interior build, the cargo floor mat, the new stickers for under the cargo door and the console cushion. I keep tracking those USPS numbers, I hate waiting.
samdjr74 is offline
Old 01-20-2015, 04:10 PM
  #57
AboveTheLogic
CF Senior Member
Just got my tracking number for the steeroids rack and pinion conversion that I ordered a few weeks ago. It should arrive tomorrow. I can't wait for that test drive once I install it!
Old 01-20-2015, 05:50 PM
  #58
LS4 PILOT
CF Senior Member
LS4 PILOT's Avatar
Parked it outside in the sunshine and waved goodbye as I drove off in the Camaro .
Perfect driving day
Old 01-21-2015, 06:08 PM
  #59
Wrencher
CF Senior Member
Wrencher's Avatar
Default new paint
Worked on the wiper door on my '69 L-68. Need to drop it off at the paint shop so they can shoot it with the rest of the car.
Gotta figure out the picture thing, I used to know how, but now I'm old
Hey, lock at that, I got it!
Wrencher is offline
Old 01-21-2015, 06:18 PM
  #60
sgt kohler
CF Senior Member
changed out the fuel pump gaskets. I put a new pump on it a few months back and noticed a very small leak at the bottom of the block where it bolts on. it was the thin paper gasket that came with the pump so I swapped it out with a thicker one I got from the speed shop. no more leaks
sgt kohler is offline
Quick Reply: What did you do to your C3 today?
Sponsored Ads
Vendor Directory
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
