Oil Pan Gasket
Oil Pan Gasket
I am replacing the oil pan gasket. Is there a better one piece gasket that is recommended? If not , what is the best four piece gasket? It's for a 75 if that matters.
When I changed the oil pump on my 69 small block a year ago I used the Fel-Pro one piece. It was highly recommended here on the CF and it worked fine for me. Use the search function to find older posts on the Fel-Pro one piece oil pan gasket.
St. Jude Donor '15
I just bought this gasket with the 4 e-z install pieces. I can't recall but what is the correct torque? Are the 4 corners the same value? Any particular recommended pattern?
I believe the corners are 20 ft-lbs, the rest are 15 ft-lbs. Check the instructions that came with the gasket and new bolts.
St. Jude Donor '15
I stand corrected,....didn't see the sheet stuck in the box. You are correct.....
