Put Her On The Road Today! Big Time "Clunking" When Backing Up
So I finally drove it after 4 weeks of looking at it! (1979) Licensed, registered and insured! Runs nice, a few rattles here and there...And this: A nasty Clink Clunk Clink Clunk (A binding feeling/sound of sorts) when backing slowly in reverse! I know there is numerous universal joints under these cars. Seams worse when the wheel is turned. I am praying it's not something in the differential. Once in gear and running up the road it's quiet and seams fine, but makes a racket in reverse. Off to work, wont be able to look at it until tomorrow or Sat...Any thoughts would be appreciated. Thanks in advance guys!
I hope that you are lucky as I was. My clunk turned out to be a brake pad pin that had come loose because someone had used an undersized hairpin clip to hold it in place instead of a cotter pin. The pin would rub on the inside of the wheel. It sounded like something was was really about to come apart. Pushed the pin back in and used the proper cotter pin.
I had a clunk when shifting....(72 4 speed) it turned out to be a wore out snubber bushing. This sound was just one clunk on every shift....Not a constant clunk-clunk-clunk. Good luck.
Brian
Brian
Thanks Brian. I decided to take it to my dad's mechanic....and a heck of a mechanic at that. I have owned the car for a month and it has yet to be on lift. I think every used C3 should go on a lift at some point. I can only see so much spying under the car in my driveway....Even jacked/blocked
1969/1971/1976 Coupes
Terry
Thanks guys! I love this site....Where is the snubber bushing mentioned above? The car needs bushings throughout. I sprayed the body mount bushing with Thrust to try softening them up a little before they get changed out.
Positraction clunk Suggest you an additive in the differential
Nam Labrat
Received 4,173 Likes
Assasin........you did what I normally do.......reply to a year old thread.
I've learned to check dates on threads before I reply.......especially when I do a Forum search----it can pull up some really old threads.
Wonder what happened to the OP......
It would be nice if the person who posts a problem, would bother to post the solution. Nice people take their time to post a possible fix and nothing from the op on what was discovered. Might be useful information to someone else.
