72 Corvette base engine headlight and wiper door actuator vacuum diagram and troubles
Does anyone have the vacuum hose diagram and troubleshooting guide for the headlight and wiper door actuators for a 1972 base engine W A/C automatic.
Al
Al
Received 2,878 Likes
Hi Al,
I believe you'll find that the Willcox Corvette site has very good vacuum layout diagrams for each production year as well as trouble shooting information.
The systems can be quite a puzzle until you've studied the information a bit, gotten to understand what each component is supposed to do and when, and then tested each component individually and independently to see if it's working properly.
Having a vacuum pump with a gauge (such as a mity-vac) can make working on the systems more straight forward.
You might also consider buying a 72 Assembly Instruction Manual if you don't already have one. The AIM can be a help in understanding where the parts are located and how they're interconnected.
Good Luck!
Regards,
Alan
Good Luck!
Regards,
Alan
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You didn't say what the door was doing? Post what is going on and I'm sure the people here will get you going.
Here is the vacuum schematic for your car.
Here is how to test the wiper arm relay.
Here is how the actuator works.
Here is how the relay works.
1968-1982 Corvette Headlamp Vacuum Diagnostic Help.
Headlamp/Windshield Wiper Actuator Relay testing. 68-72 for wipers.. 68-82 for headlamp.
69-72 Wiper Arm Vacuum Relay testing.
