Hi guys, I have a 75. My odometer went out. I managed to find a fully functional 1974 speedometer I was looking to interchange. The needle rate seems to be different however. The needle on the 75 seems to take a much faster turn rate to get spinning compared to the 74. Is this because the 75 has different internal gearing; or is it just worn?
Thanks!
I honestly do not think that GM changed the internal design of the speedometers that you are describing. they should be the same. But if in doubt...call company that restores them.
74 was last year for cable distributor driven mechanical drive tach....cast iron housing distributor with gear driven cable to Tach .....old school...lol
1975 would have used the electronic HEI tach gauge and the new HEI aluminum distributor.
Completely different systems
They should be the same although the 1975 shows km/h as well. I wish I had that one as Canada is metric. I don't think that affects the odometer. It still registers in miles.
...but he was talking about a speedometer...not a tachometer.
Yep. Speedometer. So I ended up breaking down the 74 speedometer I have. Couple of points of interest. Looks like they're built exactily the same. There's a return spring to bring the needle to 0 that seems to also provide resistance against the needle spinning, so if this spring is more tightly wound, it'll be more resistant to turning. Unfortunately I muckered up my good one, so my speedo will now forever be off several mph using the old spring
OR...send it to a gauge restorer who can fix it and make it right.
