New power window switches finished
Received 3,135 Likes
These are what caused the Parking Brake handle needing to be remade. (https://www.corvetteforum.com/forums...eply&t=3764464)
Needed something different for no valid reason. Old switches worked fine, sure a little floppy and such but functioned
Without buying a new console to drill into, what can be done with the existing cutouts....
Well, this can be made to work
Yup, I think that'll work
Zillion more wires and two pairs of relays later
And just to give the guys in the imports something to stare at, they're wired into the dash lights
Another check point on the long and winding (circular?) rebuild path
M
M
I switched everything over to LED while I had the dashes all apart and went with blue just for a change. Although noticeably brighter than the white incandescent bulbs it's still somewhat dark over in the center gauge pod but not something I'm going to get into this time around.
M
I have a one-touch unit from a taurus but I didn't get in that far this time I wired them into the keyless entry system so if you lock the doors remotely it raises both windows, but since the windows go up in about 3 seconds and the remote unit just powers them for 15 sec (not sure where they got that from) I'm worried about the motors deadheading for 10-12 second... I may disable this until I come up with a better solution.
M
Received 3,218 Likes
The relays are wired so that each gets it's coil power through the NC contact on the other relay so when the up is pressed, it breaks the coil power for the down relay, and vise-verse. Took several coffees to figure that one out but it's actually fairly straight forward.
M
M
I'm looking at doing a one-touch PW as well...albeit I'm going to use Jaguar switches!!!
Here's a piece I found that might do the trick-
"One Touch Power Window Kit
This Window Controller kit has a unique performance design that allows your windows to fully roll up or down or stop in mid stream with just one click. The microprocessor also has a safety feature that will also stop supplying power to the window if resistance occurs protecting your power window system."
Anyway, that'll be another day
M
M
M
Here when the second button is pushed, it stops the motor.
Nice work, Mooser. Looks slick, should work well, reliability will be a function of the relays (pick a good brand, they should last a LOOOONNNG time).
Much better than buying 'foreign' junk.
M
Awesome!!!! Very nice job!!!
Dub
Dub
On my poor old car the window motors have two sets of windings with the case ground where that one reverses the two contacts for up/down. The paddle switched just take the positive from the PW relay and direct it to one of the two windings.
I'll post the schematic I came up with JIC someone down the road wants it.
M
