69 Body Lift - Cape Easton Lift Off Seven
Old 02-03-2016, 07:20 AM
AllC34Me
Senior Member
Support Corvetteforum!
AllC34Me's Avatar
Received 2,031 Likes on 1,103 Posts
St. Jude Donor '10
Default 69 Body Lift - Cape Easton Lift Off Seven
Sunday, February 7th, will be my seventh body lift off (different cars) at my home garage which is in Easton, PA. I call it Cape Easton for fun, hope this doesn't offend anyone.
As with my previous offers I am opening up lift off number seven to forum members that may be interested in seeing what is involved in lifting a body off of a C-3 chassis. Most of you may have done this already so this is someone extended to those that have not seen it previously, but even if you have seen it you are welcomed to come and be a part of the fun.
I will plan to have the body ready for lifting no later than noon, most likely earlier, but will wait if folks are coming by to see it.
If you would like to participate please PM me and I can give you directions to my home.
Look forward to another successful lift off.
Best regards,
David
Old 02-03-2016, 07:32 AM
doorgunner
Nam Labrat
doorgunner's Avatar
Received 4,153 Likes on 2,726 Posts
Rats!
That's a little too far for me even though I could use the practice.........I just noticed my project body mounts are mostly...............
not there!
Old 02-03-2016, 07:50 AM
blue by you
blue by you's Avatar
THANKS FOR THE INVITE, TO BAD I AM BUSY THAT DAY.
GOOD LUCK
Old 02-03-2016, 08:37 AM
chazde3
chazde3's Avatar
You're making quick work of that one. Good luck with the lift. I'm more that likely doing mine on the 12th.
Old 02-03-2016, 09:09 AM
CA-Legal-Vette
CA-Legal-Vette's Avatar
If I was just a tad closer, I'd be all over this. About a 4 and 1/2 hour drive ( or less ). I would be very oncerned about missing the pre-Super Bowl drinking too.
Good luck! Hope it goes well.
Old 02-03-2016, 12:42 PM
SB64
SB64's Avatar
Default Lift Off
I am very anxious to see the body off. I really would like to know if the build sheet is still on the tank. I have it ready to go, see you Sat. You are a great member to the forum for offering trailer space, free parts, very passionate about C3's.
R
Old 02-03-2016, 12:57 PM
AllC34Me
Senior Member
AllC34Me's Avatar
St. Jude Donor '10
R
See you Saturday Roger.
Best regards,
David
Old 02-03-2016, 01:07 PM
AllC34Me
Senior Member
AllC34Me's Avatar
St. Jude Donor '10
With the front clip already removed from this car it will be much, much easier to lift this body from the chassis once all the bolts have been removed and connections between the body and chassis have been removed. Grounding wires, wire harness wires, bolts, etc. all have to be removed first, but we will have it off on Sunday. I'll have it ready to go early.
I'll share pictures, I promise.
Best regards,
David
Old 02-03-2016, 02:35 PM
jnb5101
jnb5101's Avatar
We all hope that there isn't a message "Cape Easton, we have a problem!"
Old 02-03-2016, 04:51 PM
chucksingh
chucksingh's Avatar
R
Old 02-04-2016, 11:01 AM
AllC34Me
Senior Member
AllC34Me's Avatar
St. Jude Donor '10
In an unprecedented move and due to favorable winds and weather, Cape Easton has moved the lift off date from Sunday, February 7th, to Saturday, February 6th and accelerated the launch.
Details will be shared when the body is successfully placed upon its body dolly and rolled outside for pictures.
T-Minus....and counting.
David Howard
Old 02-04-2016, 11:09 AM
chazde3
chazde3's Avatar
God speed sir
Old 02-04-2016, 11:24 AM
chucksingh
chucksingh's Avatar
David Howard
Old 02-05-2016, 03:25 PM
SB64
SB64's Avatar
Default Lift off
Well David picked up my donor car right on schedule. A really nice man who has a great trailer and setup. He really knows what he is doing. I can see why he has so many followers and friends and contacts. Safe trip home David and thank you for all that you do. Will be anxious to see what you find.
Regards
Roger
Old 02-05-2016, 09:02 PM
AllC34Me
Senior Member
AllC34Me's Avatar
St. Jude Donor '10
Thanks Roger. Great meeting you. Home safe and sound. Time for some wine...
Old 02-05-2016, 09:36 PM
Gordonm
Gordonm's Avatar
Already there David. Good to see you got home safely. Finished the dash and wiring today. Need to install it.
Old 02-06-2016, 07:07 AM
AllC34Me
Senior Member
AllC34Me's Avatar
St. Jude Donor '10
Wow, it looks great Gordon. Keep that momentum going buddy.
To 69 Body Lift - Cape Easton Lift Off Seven
Old 02-06-2016, 07:24 AM
AllC34Me
Senior Member
AllC34Me's Avatar
St. Jude Donor '10
I got home last night just about 8:00 pm and opened the trailer up to take a couple of pictures after transporting the 69 Cortez Silver Donor Car from Roanoke, VA to Easton, PA.
I had seen the driver side damage when I was with Roger picking up the car and my goal was to get it home before it yielded and left me a troublesome extraction from the trailer. Here are two pictures from last night showing what I found when I opened the trailer side door.
Name:  IMG_20160205_202536707 (1024x576).jpg
This is the number three body mount sitting on the trailer floor on the right side of the picture. It was attached when I left but the seven hour ride on Interstate Highways proved to be just a little too much for the old girl.
Name:  IMG_20160205_202523357 (1024x576).jpg
The good news is the passenger side has not yet yielded and may be sufficient to hold this car together for the off load and movement into my garage. That is the hope.
The only thing holding the driver side together now is the body which is coming off today. This makes removal a bit trickier, but I am certain we can do this...
Oh, and good morning to you all.
David
Old 02-06-2016, 07:30 AM
AllC34Me
Senior Member
AllC34Me's Avatar
St. Jude Donor '10
We are pretty excited about the combination of numbers matching engine, transmission, and carburetor that is sitting in the car. We will learn a lot more about it today and share what we learn, but it appears to be pretty much all there, and pretty much original. That makes a careful extraction of the motor and transmission much more interesting.
Name:  IMG_20160205_203937435 (1024x576).jpg
First I will locate the car from the trailer to the garage center bay and then shore up the car using jack stands and 4X4's. I don't want it to break in half like the titanic and damage the body before I can remove it from the chassis. Chassis stability 101. All else follows.
David
Old 02-06-2016, 06:46 PM
AllC34Me
Senior Member
AllC34Me's Avatar
St. Jude Donor '10
It was a good day. Liftoff was successful and Eric (Tyrant) stepped up and stepped in to help make this day special.
Thanks Eric.
Quick Reply: 69 Body Lift - Cape Easton Lift Off Seven
