C3 Corvette Turns to Toast After Four-Year Restoration
#41
St. Jude Donor '17, '19
Sorry to see that, I feel your pain. What causes a fire like that? I am new to c3 world. Can that happen to any c3 or was this one not put back together correctly? I'm asking because quite a few mention having a fire extinguisher and I am wondering if this is a fluke or a more common problem
#42
I could be wrong, but I think it is like a sprinkler system for your car. what is "Pumped" to nozzles strategically placed to engulf the engine and suppress a fire if a button is pressed.
I would imagine the liquid would help in a container under pressure bc if it required the car's power to work, it might now in the event of a fire. I think racing cars have special systems that emit a super-cooled liquid that basically movies around objects to suppress the fire. This could be the same thing.
GlenJack (03-29-2016)
#43
Dementer sole survivor
Received 6,260 Likes
2016 C3 of Year Finalist
The way I understand them is that its just a fire extinguisher that is hard plumbed into the car with the nozzles in strategic locations. Its always under pressure but no handle to sqeeze. You pull the pin and it goes off releasing the full bottle. I dont know where I could fit a 20 lb bottle, maybe next to the gass tank. The pin would be hard wired to the dash somewhere like a ripcord.
#44
Just did a quick search This company came up first
http://www.firebottleracing.com/shop...ystems/rc-500/
Permanent mount 5lb bottle if theres fire under the hood, light this off then open the hood and use your extinguisher that you have behind the seat if needed. $400 bucks. Not bad for the piece of mind.
Group buy?
More deals on ebay
http://www.ebay.com/sch/i.html?_nkw=...ar+fire+system
Im getting this one soon.
http://www.ebay.com/itm/Firecharger-...4AAOxylpNTVrsR
I believe This is the foam they use at airports on jet fires. And its refillable, not that I plan on using it, but its a good point
I'll do a write when it happens. Maybe a month or 2 out
Group buy?
More deals on ebay
#45
What's most painful to watch is people who don't know how to use their fire extinguisher. What good is a tool if you don't know how to use it.
When you're putting out a fire, do NOT completely discharge your extinguisher in one shot. The powder takes the air away, so, like painting a car, you put a coat over the top, (it should mostly extinguish the flames), let it cool, then another coat when the fire re-ignites. You repeat this until you're out of powder or the fire is out....
Suggestion - go to Costco, buy a two-pack of fire extinguishers. Buy a metal pan, put it in a fire-safe location, fill the pan with grease or whatever, let it light and burn for a minute to get fully engaged, then put it out. You'll learn pretty quickly that if you totally discharge your extinguisher on the first go - it won't put out the fire.....
my two cents... flame away
#47
Some other things to think about-- fire triangle-- HEAT + FUEL + OXYGEN. CO2 and Halon have some cooling effect, but generally displace oxygen so after the gas dissipates, the fire will often reflash or relight. The foaming agent blankets the fire and creates a barrier between the fuel and oxygen, less chance of a reflash, even with gasoline or oil fires.
Also, aim your extinguisher at the lowest part of the flames. And if you are practicing with a pan full of kerosene or other fuel, be careful not to splash it out of the pan and catch the surrounding area on fire.
When I was a kid, our fire department used to have " hands on " demonstrations with handheld fire extinguishers at the annual carnivals/fairs. Haven't seen any place doing that in the last few decades, though.
Simple rule of thumb-- if the flames are over your head, your 5 lb handheld extinguisher is not going to be enough-- get to a safe distance and call for help.
If you are using a water hose on a sizable fire, you can use the spray to 'knock down' the big flames, so you can get closer to it, then a stream to hit the base of the fire. And you can use water on gasoline and oil fires, just be aware of the splashing and spattering of the fuel.
#49
AFFF is good stuff! Used it in the Navy. Thanks for this link, RR.
http://www.globalindustrial.com/p/sa...FQdxvAodNvAEeQ
As a former college student who fought fires during the summer to pay for school.... I must remind, that there was a large amount of fire suppression material next to the car.... dirt. Of course, in the heat of the moment, it's hard to think outside the box... which is why practice is everything.
fire sucks, I just had a car ignite, fortunately for me I had a fire extinguisher, training, and then water to finish the job nearby.... all it cost me was a bit of paint to cover up the smoke damage.
#51
I now own a Corvette because I had a nice Mustang GT350 convertible that caught fire and burned up. Found out through my insurance company a lot of Mustangs catch fire up to the 2004 model year. My fire started inside the wiring harness. Had a cheapo Kiddie fire extinguisher in a roadside kit I bought from Costco. Pulled the pin and nothing happened after I pressed the trigger. I now carry a high quality extinguisher in my Vette.
#53
Group buy?
More deals on ebay
Group buy?
More deals on ebay
#54
1) it's easier to check that the system hasn't discharged while you were sitting
2) if there's a fire, you care more about getting out without roasting then you do about whether the engine burns
3) fire systems are susceptible to heat/cold - inside the car has, generally, fewer extremes
and for completeness
4) most sanctioning bodies require the system inside the car
with all those said, numero uno is the most important... after all, what good is an empty system?
#55
There is a company that sells automatic deployment systems, they use a glass ampule like commericl sprinklers do. I am trying to decide if that or a manual system would be better.
#56
Definitely want the bottle in an easy to "preflight" location.
SuperBuickGuy, what size bottle do you think would have put out this particular fire? Do you think the 15lb wet chemical you hyperlinked would take care of it? or the popular 5lb halon?
#57
Old school Halon 1211 (don't know for sure but I think that 1301 has similar performance), 5lb. The new DuPont FE-36 (which is often marketed as Halon by shady people) takes about 1.8ish more to handle the same fire. So for a FE36 system 10lb is recommended. It is interesting to note that the SCCA makes no distinction between the two and says 5lb is good for either chemical.
AFFF is great but the systems are kind of big if not used for a dedicated racr car, also because it's liquid instead of gas it needs more careful planning on the nozzle coverage. This also makes a mess, but it actually quenches fire. I have a AFFF system in my workshop.
#58
Out of respect I would never post anyone else cars or inside of garages etc on the internet.
The guy who made the youtube video is an ***.
Id prefer not to be filmed when under severe stress.
#59
The time, dedication and money spent to achieve a quality finished car after four years is quite a commitment, and accomplishment.
Obviously the person who put music to the video has never done it, and is clueless.
