1978 L48 Engine Restoration Completed
I just finished restoring my wife's 1978 L48. All new paint, decals, gaskets, plugs, cap, rotor, belts, hoses and filters.
All stock except for MSD wires and cap and some chrome pieces. We also did an AC conversion to R134 and installed a new more efficient radiator. The car is a Pace Car with 37,000 miles and it starts on the first crank every time.
This is not meant to be a NCRS quality restoration. It's just a nice refreshing.
PapaRaia (04-13-2016)
Very clean and nice indeed!
Excellent job! Having recently just finished an engine restoration on my 73 L48 I know and appreciate all the hard work, time and expense it took you to get it to look that nice.
Thank you for sharing it with us.
Dementer sole survivor
Received 6,256 Likes
2016 C3 of Year Finalist
Very JEALOUS. I mean very nice job. That does look assembly line fresh.
It's was an honest car in need of some TLC.
The most desirable Pace Cars are L82 4 speeds with CB radios. Ours is a L48 auto with the 8 track.
Not the most desirable options but the extra 20 hp and different transmission makes no difference when we're cruising down the road listening to Bob Segar and Journey with the T Tops off. If I want power we'll drive the 2014 Z51
Write down the Number stamped on your carb and go to a good NAPA store..They can still order up the proper stuff for YOUR carburetor..I adjusted the timing beyond stock settings also.About 9 degrees advanced really helped response and efficiecy of the motor..
I've never seen them pace car wheels up close..you did a bang up job cleaning-detailing them..Jim
Beautiful. How did you restore the wheel?
Engine bay looks great! Can't wait for pics of the rest.
Ha! Back when I had an 8- track, we cruised listening to the Fab Four--(Rush, Journey, Van Halen, The Police) and the fifth that changes- Triumph, Pat Benatar, ac/dc, Led Zepp, etc.!
Bob..very nicely done..I know what you mean about power..The old L48 350 goes down the road quick and fast enuf for this old fellow(and the laws here..)I will say that the rebuild I did on the QuadraJet with an upgraded brass float bowl.Really made a difference on my 58K motor..Considering the primary malady afflicting the old QuadraJet is a time-gasoline saturated original float and that with 37K originsal miles the car wasn't driven alot in 38 years..The rebuild is a well worth it project done with checks oin about 13 carb points, vac line p[ressures, plugs..timing..idle adjust etc by A mech familiar with ptoperly rebuilding the old Rochester QuadraJets..
I took each one off and polished it with Blue Magic Metal Polish. Two rounds with a Mother's Power Ball and 3 rounds by hand (polishing with a soft cloth between rounds).
Then I took rubbing alcohol and cleaned the face of the wheel around each hole so that masking tape would stick to the face really well. I also cleaned inside each hole with rubbing alcohol so the spray paint would adhere well. I then covered all the holes with masking tape and firmly pressed around the perimeter of the hole.
After that I flipped the wheel on its face and spray painted the inside of the holes semi-gloss black from the backside with rustoleum spray paint.
Then flipped the wheel back over and pulled off the masking tape.
I then cleaned the outside edge of each wheel with rubbing alcohol all around the faded painted red stripe. Then I applied 1/4" red vinyl pinstripe from AutoZone.
Finish them off with a fresh set of center caps.
Total Cost: $99
New Center Caps- $55
Rustoleum semi-gloss black spray paint- $4
Blue Magic Metal Cream Polish- $6
Blue Painters Masking Tape- $7
90% Rubbing Alcohol- $2
1/4" Red Vinyl pinstripe- $5
Mother's Power Ball- $20
Total Time: 5 hours
Total Beers: 9
Total Cost: $99
Total Time: 5 hours
Total Beers: 9
VistaVette (04-15-2016)
