Strut rod removal
Old Apr 14, 2016 | 06:43 PM
80-Vette's Avatar
80-Vette
Default Strut rod removal
I am in the process of replacing the trailing arm bushings and I am unable to get the shock Mount bracket off. I am more than likely going to have to remove the strut rods from the differential so I can remove the trailing arms. I think it would be easier to remove the shock mount with it off the car. The question I have is do I need to remove the leaf spring in order to get the strut rods off? The bolt is installed with the bolt head on the spring side and from looking it doesn't appear as if there is enough room to get the bolt out with the spring there.
I am not sure if that was a matter of the previous owner installing it backwards or if that is factory. I know the trailing arm bolt was in backwards so it wouldn't surprise me if that was the previous owner's handy work.
Old Apr 14, 2016 | 07:32 PM
DUB's Avatar
DUB
YES...the rear spring needs to be removed to get the concentric bolts for your strut rods out at the differential due to how they were installed.
You are aware that there is a special tool to aid in removing the lower shock bolt at the trailing arm so the strut rod can be released from it???
And hopefully you are aware that there is a special staking tool for the trialing arm bushings IF you are using the rubber design trailing arm bushing??? The rubber trailing arm bushing need to be compressed and the inner sleeve staked to hold them in.
I have encountered numerous lower shock bolts that the inner sleeve of the strut rod bushing at that area is seized onto the lower shock mount bolt....so...trying to use the special tool and NOT knowing when to stop beating on it...can cause you to break the bearing support housing.
DUB
Old Apr 15, 2016 | 10:52 AM
red topless gator's Avatar
red topless gator
DUB
Dub, how bout the shaft shock mount removal tool at Harbor Freight? Item # SU-824A. Have not used one but seems interesting.
Old Apr 15, 2016 | 12:03 PM
80-Vette's Avatar
80-Vette
I do know there is a tool for this, it is basically a pipe end cap. I am using a nut on the shaft but not having much luck. I also know there is a staking tool for the new bushings and yes I have one.
I tried looking for the shaft shock mount removal tool at Harbor Freight Item # SU-824A but was unable to find it online.
Old Apr 15, 2016 | 12:08 PM
red topless gator
I'm sorry it was not Harbor Freight, it was Zip products Inc., Phone number 800-962-9632, Item# SU-824A. Sorry for the wrong info
Old Apr 15, 2016 | 01:02 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
You can buy a couple of nuts and screw them on instead of buying a knock out tool. The knock out tool won't amplify any force struck by a hammer. I just knocked mine out and only used the castle nut screwed on backwards and flush with the end of the shock mount. I've found that a normal hammer doesn't have enough weight so I use a short handle sledge with a couple pounds of weight. Don't be afraid to give it a few hard wacks. If the spindle is gonna break, its gonna break. Or, get a sawzall and cut the shock mount. Cheaper than a new spindle.
Old Apr 15, 2016 | 02:39 PM
80-Vette's Avatar
80-Vette
If I take the strut rod off with the trailing arm I should be able to work with it on the bench. Which I should be able to use the vise and a gear puller.
Old Apr 15, 2016 | 03:24 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
You can remove the TA arm with the strut rod still in place. You may be better off then by taking it to a machine shop and pressing it out.
Old Apr 15, 2016 | 05:54 PM
DUB's Avatar
DUB
I personally would not use the tool that fits onto an air hammer. I have good air hammers but none of them have the punch that I can give it with a good hammer blow. But...if it works for someone...I am glad. I like my threaded on tool that seats against the end of the bolt so I do not damage the threads or mushroom the end of the bolt due to it being soft.
I seriously doubt that using a vise and gear puller is going to work. Keep in mind that the bolt shaft can seize onto the inner sleeve of the bushing and if you are not careful...you can snap the ear off the bearing support housing. I have only snapped an ear off ONE time in 30+ years and I have dealt with hundreds of these strut rods.....literally. So I know after a few good whacks IF I do not see movement I stop and go to plan B.
DUB
Old Apr 15, 2016 | 09:50 PM
80-Vette's Avatar
80-Vette
I don't think anyone was talking about using an air hammer. Not sure where that came from. I have not hit it with a mini sledge but I have hit it hard enough to split a 2x4. What is your plan B? The vice and gear puller was my plan B.
Old Apr 16, 2016 | 06:30 AM
rdroket's Avatar
rdroket
Put a little heat to it.
Old Apr 16, 2016 | 10:07 AM
marshal135's Avatar
marshal135
Veteran: Marine Corps
Heat is your friend
marshal
Old Apr 16, 2016 | 10:09 AM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
I'm still sticking with a bfh and a few solid blows.
Old Apr 16, 2016 | 05:51 PM
DUB's Avatar
DUB
It came from an earlier posts written in this thread referring to this tool that was mentioned in that post....that is where using an air hammer came from.
The tool is made to go onto an air hammer.
http://www.zip-corvette.com/catalogs...cat=&q=su-824a
YEP....I tried the '2x4' method ages ago..and it did the same thing....hence me getting the tool. Like I wrote before...this lower shock bolt can be seized...and YES...heat is your friend here...as like I mentioned also.
This is the tool I use.
http://www.vbandp.com/auto-parts/mis...ol-detail.html
AND YES.....it seems kinda weird to go through all of this and possibly have to replace the lower shock bolt anyway due to the splines being flattened out and not good.
DUB
Old Apr 16, 2016 | 10:52 PM
80-Vette's Avatar
80-Vette
Ah I didn't look at the zip tool so when you mentioned air hammer I was thinking you needed to put the pipe down. Just kidding.. Alright plan B is now to get the tool or to speed things along I could just get a pipe cap at Lowes.
To Strut rod removal
