Flat spot on tires??
Opinions please .......About 5 years ago I put a new set of T/A Radials on my 74 BB. Unfortunately it has sat in my (dry) basement for as long as TWO years at a time and never moved. I estimate those T/A's have about 800 miles on them. Lately I have time to get it out for an occasional drive and the tires WILL NOT balance. Terrible tire vibration over 60 mph. Discount Tire says they have permanent flat spots and will never ever run smooth.
Agree ....? Thanks!
I am about to get some new tires so I can once again enjoy this car.
Agree ....? Thanks!
I agree with the tire shop. They will get flat spots if they sit in the same spot for that long . If you know that it is going to sit that long it's a good idea to put the car up on jack stands and take the weight off of the tires.
fotyfobravo (06-07-2016)
I know this sounds crazy, and I haven't done this in a very long time, but when I was a bit younger we would get flat spots on bias ply tires once in awhile. We would fix them by doing a few burnouts........it used to work...
And then just drive on them for awhile. They would round out again. Not sure about the tires you have of there now but what do you have to lose?
Sounded reasonable ...... just wanted a verification before I replaced tires with so few miles on em'. Serves me right for not driving the old hog!
Sounds like you have some tires to waste....why not?
I've never gotten flat spots from sitting for years unless the tires went flat, but it can happen...either way if they were indoors and not exposed to ozone (like running machines next to them regularly--you did say basement), I would drive them and wear them in a bit. I've put used tires on vehicles, not my expensive vette though, that had bad spots or were take-off's that were very mis-worn from bad shocks and after a thousand miles or so, they wear in and are just fine...
you could probably sell them used and recoup some cash to someone that doesn't mind, just make sure you tell them why you are replacing them...dynabeads may help too, I actually use those in my new c4 tires and my truck since my spin balancer quit working...
that's why I mentioned ozone and storing inside. but yes normally 7-10 yrs. is replacement time, miles or no, unless they are stored properly and don't see sun/ozone/UV...
Received 1,283 Likes
Flat spots on bias belt are not the same as flat spots of radials.
You can sometimes work the flat spot out of a bias belt; much harder to do with a radial.
Use them for garage roll arounds.
