Broke college student '77 build thread
Old 02-03-2019, 01:07 PM
  #441
jrs 427
CF Senior Member
jrs 427's Avatar
GREAT thread. With all the prior coats of paint your car must have " grown " a bit. Love your white interior. It looks fantastic. My wife wants her 75 convert. painted. Maybe the black interior will be changed to white also.
Work enthusiasm is right up there. Reminds me of being 16, bought a 58 MGA roadster with a bad engine. Rebuilt the engine, painted it and sold for enough for what I wanted, a 57 Chev two door hardtop. Another deal with a bad engine. Bought a slightly used 283, installed and timed it proving to be a great dependable car.
Your C-3 will be nice transportation when finished. Most of us never have the time to get enough driving miles.
jrs 427 is offline
Old 02-03-2019, 05:45 PM
  #442
rgwoehr
CF Senior Member
rgwoehr's Avatar
Originally Posted by OldCarBum View Post
Just catching up on your thread.
Lots of nice work.
Originally Posted by Tripower delight View Post
I know its kind of late to tell you this but they make a pressure washer using water that strips leyer by layer of paint its up to you how much you wanna take off. I seen it advertise on the car cannels
I'll be painting again at some point. Probably just gonna use the razor blade method or sand it again though
Thanks. The white does look nice, the only thing that sucks is it's a major pain to keep clean. I was actually thinking about changing the color to something else last week, but then I looked at the white again and decided to just deal with it. I gotta figure out a way to salvage those seat covers though. It's so hard to clean them without rubbing through the dye. I'm hoping to get this car back to a point where I feel comfortable driving it at least once a week again, and I think I'm pretty close.
Today I made new center console side panels. I used the old ones as templates, cut them out with a jigsaw, sanded them, sprayed them down with water, and installed them. I had read elsewhere on the forum that the water helped it retain the shape. We'll see. I cut them oversize and did many test fits to get them to fit right. I'm pretty happy with them. Also I found some interior screws to use on these instead of the long wood screws used by someone in the past. If they hold their shapes well enough, I'll go buy some vinyl and spray them to match the rest of the interior. If anyone else is gonna try this, the clamps are pointless. I was hoping I could get some pressure a bit lower on the sides to get a better shape, but the clamps just slide right off when you apply any pressure. The other post I read said the screws were enough, so I'll hope for the best.
rgwoehr is offline
Old 03-09-2019, 03:19 PM
  #443
rgwoehr
CF Senior Member
rgwoehr's Avatar
I havenít done much to the vette in the last month. We had one day where the weather was nice and the roads had been washed by rain, so I drove it to work that day. I havenít wanted to spend any money on hobbies lately because Iím in the process of buying a house. If all goes well, Iíll close on that at the end of the month. I probably wonít be doing much to the vette for a while after that, but at least Iíve got it to a point where itís nice to drive.
Today I needed something to do to keep my mind off the house stuff, so I decided to paint the air cleaner. I started that a while back but the spray cans I had were dead and I just left it alone. First I tried to thin out my rustoleum enough to brush on without getting horrible brush strokes, but that didnít work well so I just stripped it down again and sprayed it with the spray gun. I have some touch up to do but Iím pretty happy with the results.
rgwoehr is offline
Old 03-09-2019, 03:55 PM
  #444
caskiguy
CF Senior Member
Support Corvetteforum!
caskiguy's Avatar
Vette things are looking great, good luck with the house. Enjoy !
caskiguy is online now
rgwoehr (03-09-2019)
Old 03-16-2019, 06:05 PM
  #445
rgwoehr
CF Senior Member
rgwoehr's Avatar
I reassembled the air cleaner today and put that back on the car. There was a bit of touchup that needed to be done but overall I'm pretty happy with the way it came out. Then I changed the front brake pads and took it out for a test drive. I almost skipped changing the brake pads after taking the first one out, but I'm glad I did it because one of the ones on the other side was almost down to the rivets on one corner. They were all worn pretty unevenly, which I'm guessing means the calipers need some work, but the car stops and the brakes don't leak so I'll leave those alone for now.
rgwoehr is offline
Old 03-17-2019, 10:27 AM
  #446
OldCarBum
CF Senior Member
Looks good
OldCarBum is offline
rgwoehr (03-17-2019)
Old 03-17-2019, 06:05 PM
  #447
C3 4ME
CF Senior Member
C3 4ME's Avatar
Air cleaner looks nice! Glad you've gotten a little seat time lately too.
C3 4ME is offline
Old 03-17-2019, 06:34 PM
  #448
Sabre34
CF Senior Member
Sabre34's Avatar
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-Ď18-'19
Looks great! I enjoy watching your progress!
Sabre34 is offline
Old 04-18-2019, 02:39 PM
  #449
rgwoehr
CF Senior Member
rgwoehr's Avatar
Thanks guys.
I closed on the house almost a month ago and my dad and I have been working on that every weekend. Just moved in last weekend but still need to get the vette over there so I can drive it more often. The weather has been pretty nice lately and I donít want to miss out on the nice corvette weather before it starts getting hot and humid again. Iíve been a little hesitant to park it in my garage because thereís a bunch of termite damage and the repairs that have been done to it seem a bit sketchy, but weíve had some strong winds and itís still standing so I guess itís not as bad as it seems. But Iím hoping I can either repair or replace that thing within a year or two.
rgwoehr is offline
Old 04-18-2019, 10:35 PM
  #450
doorgunner
Doorgunner's '68 Project
doorgunner's Avatar
The engine bay looks great. Keep at it (and tell me to do the same!).
doorgunner is offline
Old 04-26-2019, 08:11 AM
  #451
rgwoehr
CF Senior Member
rgwoehr's Avatar
Thanks. Glad to see your car is at the painter
rgwoehr is offline
Old 05-14-2019, 12:37 PM
  #452
rgwoehr
CF Senior Member
rgwoehr's Avatar
We pulled my uncles vette from the guy that was doing the bodywork on it for the last 3.5 years and got the car out here a couple weeks ago. Just for fun, I decided to take his passenger side T top and put it on my car to see if it fit better than mine. His fit great, mine not so much. Now I need to figure out what’s wrong with mine because I can’t adjust it any better than the photo below.
Last time these cars were together was October of 2015, right before my uncle and I dropped his car off for bodywork.
rgwoehr is offline
Old 05-14-2019, 12:51 PM
  #453
M4A3E2
CF Senior Member
M4A3E2's Avatar
If I remember correctly, the t-tops are 3 or 4 pieces. Make sure that everything is glued/velcroed/whatevered together well. Mine are starting to gap up a bit.
M4A3E2 is offline
Old 05-14-2019, 01:47 PM
  #454
caskiguy
CF Senior Member
caskiguy's Avatar
We pulled my uncles vette from the guy that was doing the bodywork on it for the last 3.5 years and got the car out here a couple weeks ago. Just for fun, I decided to take his passenger side T top and put it on my car to see if it fit better than mine. His fit great, mine not so much. Now I need to figure out whatís wrong with mine because I canít adjust it any better than the photo below.
http://repairs.willcoxcorvette.com/w...-aim-77-82.pdf
Old 05-14-2019, 03:37 PM
  #455
hicswa
CF Senior Member
hicswa's Avatar
What did you spray it with? Is that semi gloss black?
hicswa is offline
Old 05-14-2019, 09:14 PM
  #456
rgwoehr
CF Senior Member
rgwoehr's Avatar
Thanks. I’ve tried messing with the adjustment several times but it just won’t move any further in. I think the weatherstripping might be getting in the way because it doesn’t seem to be installed right. It doesn’t sit on top of the stainless trim like I’m guessing it’s supposed to. It just bunches up along the side of it and doesn’t seal.
If you’re referring to the air cleaner, I used rustoleum high heat BBQ paint. I bought a quart and thinned some of it and sprayed it with a spray gun. I think it’s satin.
rgwoehr is offline
Old 05-20-2019, 10:38 PM
  #457
rgwoehr
CF Senior Member
rgwoehr's Avatar
Iíve been driving the car a lot lately. I noticed in certain angles in the sun, I could see a bunch of little lines that I thought were just sanding marks that were too deep for the paint to fill. I pulled it into the garage today and the light caught it at the right angle and I saw that they were actually cracks. I think these are pretty new because I donít remember seeing them when I polished the car last year. Pretty annoying but not shocking considering all the other flaws in the paint. Hopefully in a few years Iíll be in a position to repaint the car with better tools and materials.
rgwoehr is offline
Quick Reply: Broke college student '77 build thread
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
