Fuse location
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
There is a 25 amp fuse in the fuse panel but it only supplies power to the brown wire which is what powers up the other speeds. The red wire at the high blower relay goes straight to the engine and forward lamp harness on circuit 2 and is hot all the time with the ignition switch turned on.
What problem are you trying to figure out?
Here is the factory schematic... http://repairs.willcoxcorvette.com/w...tic-tracer.png
enlarge it, then right click on it and select copy.... then open your paint program and paste in in there, save to your desktop.
It'll be more readable then this is for sure.
