Looking for Advice on Cluster Circuit Board
I am looking for a recommendation on a vendor or source for the instrument gauge cluster flexible circuit board. Are they all about the same? Working on my '82 which has a several issues and has not been on the road for a while. The Check Engine light was out so I pulled the gauge cluster and replaced all the bulbs. Now I can't get the lights and gauges to work correctly. Tried carefully cleaning contacts with eraser and reconnecting several times but they are still intermittent. Checked wiring and circuit board with meter and voltage source and they all checkout. So it appear that the flexible board is too stiff or dried out to make good contact with the wiring harness. Thanks!
-Chris
-Chris
Bigredwing (08-03-2016)
