Is this what an alternator belt should look like?
Old 10-23-2016, 05:02 PM
Docbrock
Docbrock's Avatar
Default Is this what an alternator belt should look like?
I have not been under the hood of too many cars, but I was just doing some basic checks of hoses and fluid levels, and I was puzzled by the "notched" look of this belt.
I assume this is the alternator belt, and I also assume that those notches are supposed to be there. The belt did not feel brittle and did not appear to be slipping.
Any thoughts?
Old 10-23-2016, 05:04 PM
Docbrock
Docbrock's Avatar
Oh, more information, this is a '72 C3 with a 350
Old 10-23-2016, 05:05 PM
76vette1
76vette1's Avatar
The notching is not unusual. Many belts have them. The cracking has me concerned. I would replace it.
Old 10-23-2016, 05:06 PM
Docbrock
Docbrock's Avatar
What is a good price on one of those?
Old 10-23-2016, 06:17 PM
USAFVeteran
USAFVeteran's Avatar
Replacement belts are available at any parts store in person, Rockauto.com and I'm sure they are reasonable to buy.
Old 10-23-2016, 06:33 PM
resdoggie
Had a 1976 L-82, 4-sp
Support Corvetteforum!
resdoggie's Avatar
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes on 925 Posts
Royal Canadian Navy
I would replace the belt with a wider width because I think yours may be a replacement belt due to age of car and should have been wider. I could be wrong.
Old 10-23-2016, 06:35 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi Db,
The original belts on your 72 weren't notched, but as has been said, many locally available replacement belts are.
(Maybe the notches give more 'grab' as the belt stretches?)
Regards,
Alan
Docbrock (10-24-2016)
Old 10-23-2016, 07:22 PM
jnb5101
jnb5101's Avatar
I think the pictured belts are too narrow. There should not be a gap on the sides of the belt where it should contact the pulley. The belt should ride up in the sheave with an air gap under the belt. Friction is generated on the sides of the belt, not the bottom. Check with someone that has a Parts and Illustration catalog for the exact width and size of the needed belt.
Old 10-23-2016, 07:36 PM
Mooser
Mooser's Avatar
Received 3,134 Likes on 2,068 Posts
The original belt (looks like you've just got the alt there)
Replacement belts should match the width and effective length
Here's a Dayco belt spec
Dayco PN 15525
Effective Length (in) 52.50
Top Width (in) 0.44
Metric Part 11A1335
Outside Circumference 53.07
GM PN 3847704
HIH
M
Old 10-23-2016, 07:45 PM
Mooser
Mooser's Avatar
Oh, forgot
The notches on the inside of belts are usually there to reduce the compression on the belt going around a pulley, allows it to bend easier, believe it or not this reduces the heat build-up in the belt (and slightly improves the efficiency but that's not normally considered in design)
Notches on the outside of belts (ie Dayco topcog) don't relieve the compressive stress but do create more airflow around the belt to help cooling as well as making them more flexible (supposedly helping to prevent belt flip but I've never seen that as a problem anyway)
Most belts today will likely have inside notches like your
M
Old 10-24-2016, 11:20 AM
toylman
toylman's Avatar
The Dayco is currently $1.28 at Rock. Scroll through the list. Rock Auto is a great mail order source
https://www.rockauto.com/en/catalog/...rive,belt,8900
Dayco PN 15525
Top Width (in) 0.44
Metric Part 11A1335
GM PN 3847704
HIH
M
Old 10-24-2016, 02:27 PM
C3 Stroker
C3 Stroker's Avatar
The notches are OK, but the belt is definitely dry rotted. I'd replace it ASAP.
To Is this what an alternator belt should look like?
Quick Reply: Is this what an alternator belt should look like?
