70' Rebuild has begun
Old 02-20-2019, 03:55 PM
  #401
CraigH
CraigH's Avatar
Originally Posted by caskiguy
Read this post:https://www.corvetteforum.com/forums...reservoir.html
There are 6 screws inside the fender well, turn them slowly. You might be able to remove only the Master Cylinder, from experience the Vac Booster is a bit of a challenge but what's new ? If you remove the side grill you can reach up to the canister to hold it as you unscrew the last 2 screws.
Best of luck, if I can help ask and I'll do my best to answer.
Read post 6 for Booster removal. https://www.corvetteforum.com/forums...r-removal.html
Good links. I am looking to put an original vacuum tank in my 71.
Power Booster is possibly on way out so opportune time to give it a go.
Added to my current list :-)
caskiguy (02-20-2019)
Old 02-20-2019, 05:28 PM
  #402
Richard454
Richard454's Avatar
Received 3,220 Likes on 1,732 Posts
Hey Brian-
DO check out your tank carefully-
Mine looked great to but had some hairline cracks-there are several other members that were unpleasantly surprised to find the same problem.
here's a thread from Dub on how to repair...just in case. Soapy water and a air hose is all you need to test.
https://www.corvetteforum.com/forums...nk-repair.html
Old 02-20-2019, 06:57 PM
  #403
caskiguy
Support Corvetteforum!
caskiguy's Avatar
Originally Posted by Richard454
Hey Brian-
Thank you Richard. Will do !
Old 02-23-2019, 07:28 PM
  #404
caskiguy
caskiguy's Avatar
Make my way through the final part removal
Old 02-23-2019, 07:30 PM
  #405
caskiguy
caskiguy's Avatar
Old 02-23-2019, 07:36 PM
  #406
caskiguy
caskiguy's Avatar
Number 4 Passenger side body mount area
Number 4 body mount with cut bolt still attached & 49 year old rivet stem. LOL It's a keeper !
Primoz (02-24-2019)
Old 02-24-2019, 02:34 AM
  #407
Primoz
Primoz's Avatar
2017 C3 of Year Finalist
They are in good state after all these years! Definately a keeper!
Old 02-24-2019, 04:30 AM
  #408
CraigH
CraigH's Avatar
I ended up importing imported two vacuum tanks.
First one looked great but when I prepared it for paint it was coated in body filler. It made it air tight....or sort of. I stripped it all back and got welder to braise it up but we gave up as there was so many pin holes.
Imported a second and that is much better have not got around to installing....hopefully soon if I need to change the booster.
Old 02-26-2019, 07:21 PM
  #409
caskiguy
caskiguy's Avatar
1970 Vacuum holding tank
Not holding vacuum. Will need to have it sandblasted and then look for crack as I don't see any present after cleaning it. It may also be a bad seam. Fingers crossed.
Old 02-26-2019, 07:28 PM
  #410
caskiguy
caskiguy's Avatar
Windshield removed today. 15-20 minutes and bingo ! Done. Frame is in excellent condition for which I'm grateful.
Old 02-27-2019, 12:28 AM
  #411
caskiguy
caskiguy's Avatar
Alright completely missed your suggestion Richard. Wow can I be slo at times.
Old 02-27-2019, 06:29 AM
  #412
SB64
SB64's Avatar
The windshield area does look really good for making it all these years. A lot of cars aren't as lucky, I know I was not.
RVZIO
What a surprise I got!
I was amazed at the time that all of this was hidden. An eye opening experience.
All of that was hidden from me under the windshield trim. I thought I bought a nice original 69 coupe.
Old 02-27-2019, 09:34 AM
  #413
caskiguy
caskiguy's Avatar
RVZIO
It was quite a relief to find no issues. Judging from what I've seen on the forum I've been blessed.
Thanks for looking RVZIO
Old 02-28-2019, 12:02 AM
  #414
caskiguy
caskiguy's Avatar
FYI to anyone needing information on glass replacement:
Read post #8 from pws69:
https://www.corvetteforum.com/forums...placement.html
https://www.corvetteforum.com/forums...indshield.html
https://www.corvetteforum.com/forums...questions.html
Man I miss Alan71'
Old 02-28-2019, 01:56 AM
  #415
caskiguy
caskiguy's Avatar
More stuff on Windshields and setting them correctly.
Originally Posted by RPOL68 Butyl ribbon is easier and less messy than urethane sealer that is used on later vehicles. I'll avoid the butyl vs urethand debate here.This debate really bugs me.
It is no debate among professionals and AGSS ANSi Standards.
I have posted info on another ongoing post.
I was a Certified LOF Installer for 15 years back in the early 70's and 80's. Have kept up with it ever since.
All C3's used Thiokol or Urethane from there inception.
Here is the product data sheet from 3M.
It says it all.
http://multimedia.3m.com/mws/mediawe...SevTSeSSSSSS--
It is to be used as a supplement with urethane. Shear strength of Window Weld butyl is 15 PSI shear strength of cured urethane is 550 PSI. How much energy do you think your body has in a front end collision or roll going 70 MPH? It is as important as seat belts to keep your body in the car.
3M Window-Weld
Tacky, solid sealers designed for use with structural urethane adhesive to bond automotive glass to the car
body in full cut installation procedures. It may be used for installing windshields, backlites and bond to
primed metal and glass. Compatible with urethane, polysulfide and butyl sealants.
Directions for Use
1. Remove all old sealant.
2. Prime bare metal with appropriate primer system (urethane primer if products used with a urethane
adhesive).
Clean glass with 3MTM 3. Glass Cleaner-P.N. 08968.
4. Position windshield or backlite on pinchweld.
5. Be certain sealer makes complete contact between glass and pinchweld.
6. Use hand pressure on glass to insure a good seal.
7. Back fill with liquid sealant.
8. Water test using a gentle spray of water on roof.
Applications
For installation of stationary glass when used as supplementary sealer/bonding material with urethane
adhesive
Directions for Use
3M glass products are intended for use as part of the repair process outlined in service manuals provided
by automotive manufacturers. For detailed instructions by car model, refer to information available from
the automobile manufacturer.
3MTM Windo-WeldTM Ribbon Sealer is designed and intended for use as a replacement to original
equipment butyl installations or as a supplementary sealant when installing stationary glass with urethane
adhesive.
** 3MTM WINDO-WELDTM RIBBON SEALER IS NOT INTENDED FOR A WINDSHIELD OR
BACKGLASS WHERE OEM URETHANE WAS ORIGINALLY USED.
For urethane set glass, refer to
and follow 3M Auto Glass Replacement Urethane directions. In some urethane set applications, use of
this product may be appropriate as a supplementary sealant.
Old 03-04-2019, 11:24 AM
  #416
caskiguy
caskiguy's Avatar
Note to myself/ Windshield frame paint: https://www.corvetteforum.com/forums...or-primer.html
http://repairs.willcoxcorvette.com/w...stallation.pdf
Primoz (03-04-2019)
Old 03-22-2019, 01:48 PM
  #417
caskiguy
caskiguy's Avatar
Ordered my new engine today ! BLUEPRINT/400CI/460HP/470TQ/ WEIAND - WE8120WND INTAKE/ HOLLEY 750CFM-4150/ DIST-BPP3503BK
To 70' Rebuild has begun
Old 03-22-2019, 02:23 PM
  #418
Primoz
Primoz's Avatar
Old 03-22-2019, 07:27 PM
  #419
OldCarBum
OldCarBum's Avatar
Received 4,691 Likes on 2,934 Posts
Nice!
Old 03-22-2019, 08:57 PM
  #420
Richard454
Richard454's Avatar
Great!!! That ought to give you AND the car some serious motivation!!!
Hmmmm- I don't see a pad to stamp "MATCHING NUMBERS!!!"
Quick Reply: 70' Rebuild has begun
