L89 block mismatch
The car that Corkscrew has referenced has a VIN for a 1969 Corvette built in late October 1968... An I 4 9 casting date would mean the block was cast eleven months after the car was built... That's a problem. If we are misreading this and it is an I 4 8 casting date, then the casting date is in a location it probably shouldn't be until three or four months later. On top of that, the engine is coded for an option that supposedly wasn't available for another three of four months as well.
Interesting situation...
Regards,
Stan
Good information. Might be brain fade, but I don't recall style of "4."
Assuming the "4" is correct, it appears to be I 4 9... Located on the bellhousing of a 3963512 block. For September 4, 1969, the 3963512 casting would probably be the only casting number being used for a 427 and puts the block casting date in the location it should be.
Now the problem comes when you get to the pad.
The pad surface is obviously damaged... The dual disc clutch may not have been available... The block casting and assembly dates are after the car was built (by almost a year)... There are some other pad issues that might be in play as well.
If the date actually is I 4 8, then you run into the question of the orientation of the date... Why isn't it on the side of the block?
Throw in the fact that there is no documentation on top of all of that.
If it is a neat old car and the purchase price wasn't/isn't too high, a lot of what we are looking at really isn't critical... Just drive it and enjoy it. If, on the other hand, you're looking at a high dollar car billed to be the "real deal," then you may want to look at other options.
Do you own this car or are you looking at it as a potential purchase?
Regards,
Stan
And the big question, how much are you willing to spend?
http://americanclassicscars.com/chev...num-heads.html
I have not driven the car; just saw it start and run when seller put it up on lift so I could inspect it. Underside looks great, exterior is also very good. Interior could use some freshening. I will be back in WA on the 24th. If it is still there, I will do a closer inspection and test drive and then report back.
Having said that though, if you could pick it up for 30 something (low 30's), I think you would have a pretty descent car for the price. The tri power set up and 1969 aluminium heads are each about 3 grand alone.
Remember the solid lifter rectangular head L71/L89 is a cranky beast by nature. When I ran it it was running fairly well. As for the frame damage, that may be a different story, I didn't see any evidence of that but didn't get very deep into it.
Just me 2 cents worth!
If you really want an L71, why don't you take a look at that blue hardtop that is for sale on here for 42,000. Or the Red convertible 1968 L71 near San Francisco for 53,000. They both look pretty original and I think you get a better more honest car buying on here.
Can't thing of any real L89 for sale anywhere for less than 60 g's at the moment
