trailing arm bushing tool needed
3rd Gear
I am looking to stake my trailing arm bushing so I was wondering If anyone had a press style flaring tool to sell or rent? Or is there another way to get the job done?
I have one that I don't intend to use again. I've loaned it out a number of times but I think it's time to start reducing some of my inventory. I'll ship it to you for $35, includes postage. PM if interested.
Just my advice - I reused my oem side plates. They have a deeper bevel and the staked bushing flare seats in there nicely. The new ones did not have a deep enough bevel and the flare was sticking out, screwing with the shims. I would loan you mine but last time I didn't get it back for 6 mos.
That's a great offer from 64, but you could also build your own.
https://www.corvetteforum.com/forums...tion-tool.html
Brian
See I do listen DUB....Thank You for the tip. Right side is finished and ready to go back on the car.....I have the parts coming tomorrow to begin putting the left side back together.
Brian
Brian
DUB (01-09-2017)
And something that IF a person is replacing the trailing arm pivot bolt. I would highly advise setting it up in place and checking to make sure the castle portion of the nut will do line up with the hole in the bolt.
Often times when they drill the hole in the bolt..it is not in the same location as the facotry one. Thus it may require you to add another washer at the head of the bolt.
AND...if they give you a cheesy castle nut that does not look beefy as the factory one. I re-use the facotry castle nut. Because I always look at this area when a Corvette with these type of trailing arms comes in and IF the nut has been changed...or the cotter pin can not even do its job because the hole in the bolt is out past the castle nut...I begin to 'wonder' if they did it right....and many times they did it completely wrong.
Also the torque on the trailing arm pivot bolt is 45 lbs/ft.
DUB
DUB
