Sticking seat belt. This worked for me.
Old 01-18-2017, 07:34 PM
540 vette
540 vette's Avatar
Default Sticking seat belt. This worked for me.
One of my lap belt retractor was jamming up and not holding and retracting. I drilled 1/8 inch holes in the plastic covers at each end and squirted some WD40 into them and let it sit for awhile. Then I ran the belt in and out a few times and now it works great. Maybe this will help someone.
The following 3 users liked this post by 540 vette:
20mercury (01-18-2017), Freddy76 (01-19-2017), Rescue Rogers (01-19-2017)
Old 01-19-2017, 09:25 AM
Freddy76
Freddy76's Avatar
Thanks, I was having the same problem.
Old 01-19-2017, 03:07 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
Such problems are usually due to sticky retractor mechanisms (as you described) or from belts with fraying edges getting loose fibers caught up in the retractor. If the latter is the problem, trim off all loose webbing fibers and plan on getting the belt webbing redone or replacing the belts in the 'not too distant' future.
Old 01-19-2017, 07:44 PM
540 vette
540 vette's Avatar
My belt webbing and labels on the webbing were in perfect condition. Just the passenger lap belt were the labels a little dirty.
Old 01-19-2017, 10:59 PM
7T1vette
7T1vette's Avatar
Your lubrication approach has likely resolved the problem.
Old 01-20-2017, 06:16 AM
Sluefoot
Sluefoot's Avatar
I would think spray silicone would be better....wouldn't smell as bad
Old 01-20-2017, 12:38 PM
Kevin BC
Support Corvetteforum!
Kevin BC's Avatar
My seat belt will tighten and not release. For example in spirited driving when I hit a bump and bounce in the seat the seat belt ratchet will tighten and not release. Is lubrication a fix for this also?
Old 01-21-2017, 01:30 AM
7T1vette
7T1vette's Avatar
Probably. There is a counter-weight in that retractor that will latch the mechanism when negative G-forces are present. It should release when force is negated, but the pivot could be corroded or sticky for some other reason.
I would pull the belt all the way out of the retractor and hold it there while spraying some lube into the mechancism. That way it won't discolor the belt webbing and more lube may find its way into that gizmo. My preference would be to use white lithium spray lube, rather than silicone (which evaporates rather quickly) or WD-40 (which is a Water Dispersant...not a particularly good lubricant). But, whatever you have that works is fine. If you think there could be rust internally, PB Blaster would be good.
To Sticking seat belt. This worked for me.
Quick Reply: Sticking seat belt. This worked for me.
