72 horn relay
72 horn relay
Short story. Horn stopped working on my 72. Can hear relay click when horn button is pushed, but no noise from horn. Ran a wire direct from a 12v source to horn and it honked so it's not a bad horn assembly.
No power to green wire coming out of relay when horn button is pushed so that's why horn isn't honking, so i am thinking it's the relay. Am I missing something here or do I just need to order a relay?
2018 C3 of Year Finalist
2016 C3 of Year Finalist
I had the same problem a few years ago with my 72. If I remember correctly I took the cover off of the relay, cleaned the contacts, and it started working again. I also remember that the relay is attached to the fenderwell through two rubber grommets that are easy to lose and hard to replace.
SWO vette (02-01-2017)
