Plastic Fantastic tew
#222
No, I haven't forgotten this. My friend with the mill is on vacation until early next year, so the front brake/spindle mods get to wait, also I have a stack of postponed projects that really need movement (e.g. Colorado air compressor, rack, lights, sliders; Suburban stuff). Also, the next step after the brakes is pull the body off. That, of course, fills my shop and lift - so the other projects plus my wife's craptastic Jeep JK Rubicon (which is leaking coolant, again) means I need to put this on a 2 month or so hold... leaving the body on the frame makes it far easier to move.
in other news, I've been building a plasma table so I can make nice pieces for the frame work that is soon to come
#223
package it up to roll it out.... radiator
yeah, doesn't fit.... ah well - it's not far off
side shot
time to move it out of the way for a couple weeks
side shot
#224
there are washers under the passenger side mount to get the pipes to fit in their correct place.
#226
move the front suspension back 3/4" or move the flare....
I'm really leaning towards moving the flare and then giving it more flare along with a slightly different shape.... cut right there between the rear of the wheel and the gills.
Metalhead140 (01-09-2019)
#227
not what I found, in my world the manifold bolts to the head so how the hell you adjust that with washers I would like to know, please explain. Then the sidepipes fit to the collector tube at the other end of the manifold and run down the side of the chassis/ rocker panel. Your washers are for mounting the insulation rubbers, the location of the collector is a function of the manifold geometry and on two separate manifolds it was of.
#228
and this is exactly why I don't participate anywhere else on Corvette Forum... everything is an argument - even how I did something months ago. But as we have a good example - let's be clear, I post what I do.... you have a question about what I'm doing, ask. That said, my life is too short to even consider feeding trolls.
The following 2 users liked this post by SuperBuickGuy:
73sbvert (01-14-2021),
Metalhead140 (01-11-2019)
#229
time to remove the body bolts
mmmm... good sawblades
a good example.... the first two came out just fine (motor end), second took a bit of lube....
the last, a neanderthal
this is more for me - but I'm moving everything back 3/4" so knowing where the steering was will be useful when I build new motor mounts
gtmsomeday (01-11-2019),
#230
edit
I bought the coating for the frame.... so once it's squared, plated, shortened, made pretty... a coat of paint and it'll be good for a long, long time
#231
a mistake... and what will stop me from completely getting the body off
up we go, hmm, nose low
once I removed the bumper brackets, and the clutch fork... up
and stopped here
did you guess the problem? the 68-73 rear curls under the rear valance .... had I put those jackstands on dollies - I could have moved the frame forward then completed the lift-off.... and my jack said "oh hell no" so tomorrow get a new jack then finish this.
and stopped here
#232
So I did do jack today... twice
new hotness
old brokenness
wait.... which one is broken?
I was all ready to proclaim how my Costco jack outlasted 2 HF jacks.... which, old brokenness did... problem was that was a factory sealed new one that was broken when they put it in the box.... ah well, just 2 hours I'll never get back
putting the new, new one to work
and the divorce is final
finally get to use this cart
this didn't last long, but it fits so I can move stuff around if needed
stiff stripped off..... more to come
new hotness
old brokenness
gtmsomeday (01-13-2019),
Rescue Rogers (01-14-2019)
#233
time to use my frame floor
oh yes, and tape measures
it really wasn't that far off (within GM manufacturing tolerances for the day).... but I can do much better, so I will
the challenge, of course, is getting it square to the floor (after verifying squareness of the frame)
lots of this action
It's close, I'll let it settle over night then do the front. The back is 1/16" off square, so I'll fix that as well... but that is for later this week
lots of this action
#234
Dementer sole survivor
Received 6,278 Likes
2016 C3 of Year Finalist
I'ld give those dollies a good nudge, in case they are hung up on some debris, to help it settle. Looks greaat!!!! thanks for the pics!
#236
time to make this real - of course, that means cutting it apart and making it look pretty.
the first step is to weld plates on the rearmost channels to hold things in place
measuring process
and it's cut apart.....
measuring process
#238
Oh look, Jeep on a trailer.... what keeps sbg from PF2? yeah, a blasted Heep.
in other news, the Colorado hauls the Jeep even better then the Hummer did - though it may be the Ford hubcaps on the trailer, after all Fords get towed very well
yet I still did get to fun stuff
even had a minute to hit the frame with a wire wheel in prep for welding the frame. I think I'm going to weld it with the motor in place then pull the motor, flip the frame then weld and brace the rest....
gtmsomeday (01-22-2019)
#239
time to start welding.... motor is in and it's resting level and on its suspension points.... and the frame wasn't flat, so I'll weld it flat in this process
look at the 'weld' to the left of the mig weld.... this is why welding the frame is so important
this hole gets filled too
and the fun of straightening the usually bent rear brace
#240
weld frame to make square..... and beat on frame....
along with hanging weights, I did some flame wrench straightening .... frame is dead nuts square, but it has a slight rack to it (thus the weights)
someone told me once that it wasn't possible to shim the side pipes up with washers..... to that person, don't look
the problem, it turns out, I'm fixing anyway with a new driver's side motor mount (so it clears the steering shaft
time to start welding plates on
other side
other side
