Plastic Fantastic tew
Old 04-12-2019, 09:40 AM
  #321
SuperBuickGuy
CF Senior Member
SuperBuickGuy's Avatar
extent of the problem
passenger side is fine
Needed bench space so put the tank roughly in place
so the plan.... at $300 plus shipping, there is zero chance I'm not building a replacement part(s) myself for the floorpan...
SuperBuickGuy is offline
Old 04-15-2019, 12:09 AM
  #322
SuperBuickGuy
CF Senior Member
onto floor flixes, first treat the rust on the passenger side
this will need something a bit more substantial
CAD
now in metal
Old 04-15-2019, 11:44 AM
  #323
Rescue Rogers
CF Senior Member
Support Corvetteforum!
Rescue Rogers's Avatar
2016 C3 of Year Finalist
I did the same thing for an early 70's Jeep I had to rebuild. Welded in nicley and it was thicker and stronger than the original....
Good job
Rescue Rogers is offline
Old 04-17-2019, 12:19 AM
  #324
SuperBuickGuy
CF Senior Member
Foretaste of the Buick wagon that's coming next
cut hole, remove undercoating
remove metal from flange
spray with weld-through primer first to mark the edges
eventually I'll weld this on both sides, but this is a start
and finally another project in the wings
initially I was/may weld this - but the cap retainer would need another solution
Old 04-17-2019, 07:22 AM
  #325
PainfullySlow
CF Senior Member
PainfullySlow's Avatar
love the innovation and attention to detail here. I really enjoy following your thread. Keep up the good work and that billet cap looks amazing =)
PainfullySlow is offline
Old 04-18-2019, 11:24 PM
  #326
SuperBuickGuy
CF Senior Member
Finish up the floor detour
a few notes.
1) the floor is going to get the ceramic coating that the FJ40 got - it's 1/4" thick so those seams disappear as does the rust pits on the other side
2) underneath it gets undercoating so the patch will fully disappear (like it did on the '40)
3) FOR THE LOVE ALL THAT IS HOLY STOP BLOCKING WINDOW CHANNELS WITH ADHESIVE WHEN YOU HAVE A LEAK... damn fools, GM designed the windshield system to allow the water to run under the molding then away from the car. The molding keeps water from being driven into the windshield frame. This car had a leak, and they plumb filled up the channels with window adhesive.... the leak is in the valley (below the window) .... just remember this, if I see you, Bubba, doing this I pray for your eternal soul to be damned to a hell where you do nothing but try to weld up pinholes, naked, and over your head. Prayer works, so you are now on notice there is an 11th commandment.
onto cleaning the body so I can complete the color change
and rebuild the rear floor... I think I'm simply going to raise it to clear.... there's little reason to give it huge luggage space and it's far easier to just bond it back 2" higher.
Old 04-21-2019, 11:59 PM
  #327
SuperBuickGuy
CF Senior Member
more.... I spent most of the day on honey-dos, so I had 2 hours tonight to get further....
doors are off
I knew pulling the booster was a pain, double the pain for a true 4 speed car because there are more bits in the way
however, I won
ish.... I still have to put the other back in
ah well, having brakes that will suck the tailights through the gas tank will be awesome.
Old 04-22-2019, 08:49 AM
  #328
doorgunner
Doorgunner's '68 Project
doorgunner's Avatar
"Ahhhhhhhh…..the thrill of restoring C3 Vettes.....it has to get real ugly before it gets real pretty"
doorgunner is offline
Old 04-23-2019, 12:37 AM
  #329
SuperBuickGuy
CF Senior Member
not really restoration, the center of the frame is similar to stock and the top of the car, from the fender edges up is stock..... except the gas fill.... nose and tail are not.... lights won't be, hood is an idealized version, interior may have one or two bits... motor, not at all... trans is, for the moment stock.... but how bent and beat this was, this is the best use of it.
Hydraboost
cut on the line
bright side is the plate fits, down side is the hole is too high
by an inch
unthread brake pivot
verify thread pitch
cut and thread
verify distance
I've had this Corvette style MC forever, it has the right internals, but the thread pitch is completely wrong for anything I've had before... more likely it will continue to be a test part... but it's nice to have one to check before I buy.
other end, using the right master cylinder
not the right one
Old 04-23-2019, 12:59 AM
  #330
caskiguy
CF Senior Member
caskiguy's Avatar
Nice work guy !
caskiguy is online now
Old 04-26-2019, 12:33 AM
  #331
SuperBuickGuy
CF Senior Member
another bite of the elephant
Old 04-29-2019, 12:40 AM
  #332
SuperBuickGuy
CF Senior Member
it feels slow from my chair... but thank you, I appreciate the compliment
I didn't get much done today, but a bit did get accomplished
like making a hole bigger
ground on this then painted it
goal here was to set the height of shelft
once I finish the booster, I'm pulling the body off again to glass the shelf, the inner wheel wells, and the inner fenders, then, of course, plumb the frame. Hopefully when done with that list the body goes on for permanent
Old 05-01-2019, 12:14 AM
  #333
SuperBuickGuy
CF Senior Member
oh what a pain this is....
necessary tools to install
necessary tools for the brake, clip clip
this one was the hero of the evening
installeded
Metalhead140 (05-02-2019)
Old 05-15-2019, 11:59 PM
  #334
SuperBuickGuy
CF Senior Member
back to this....
up we go
fix the tank bracket
set the FI tech on
and now spend a lot of time sitting and staring at the tank with all the fittings I have to come up with a plan
Old 05-16-2019, 01:01 AM
  #335
doorgunner
doorgunner's Avatar
Looking good. I'm doing the same thing with a custom gas tank.. How are you going to route the filler neck....(are you using the original gas lid opening?)
Thanks.
Old 05-16-2019, 08:25 AM
  #336
gtmsomeday
Junior Member
gtmsomeday's Avatar
It's been over two weeks since an update!
gtmsomeday is offline
Old 05-16-2019, 10:34 AM
  #337
SuperBuickGuy
CF Senior Member
Thanks.
yes, original opening - I'm welding and offset tube to it then hose clamping
Old 05-16-2019, 11:31 PM
  #338
SuperBuickGuy
CF Senior Member
more fitting - seems I got a bit generous with the motor mount
chop chop
close, time to tilt the motor
better
OMG washers
and brake lines
random land cruiser pic....
Old 05-20-2019, 12:41 AM
  #339
SuperBuickGuy
CF Senior Member
some parts came in... just one bender shy of being able to do this
and I think I'm one connector short (didn't order, oops)
Old 05-22-2019, 12:54 AM
  #340
SuperBuickGuy
CF Senior Member
Plumbing
I got stopped on the brakes because the distribution block is not safe to use... no worries, they're cheap.
Fuel line
battery is going there
Metalhead140 (05-24-2019)
Quick Reply: Plastic Fantastic tew
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
