I'm A Tumbling Fool - Or Cleaning Bolts The Easy Way
what media do you use and how long do you tumble?
i bought a tumbler from harbor freight.. not the drum type though, the shaker type...
perhaps its my lack of patience, but I don't get anywhere near that result.
yes, i just hit my cleaned bolts with semigloss clear spray.. stops the rust.
I bought a sonic cleaner from Harbor Freight, and I have a tumbler for my reloading. I use walnut shells in the tumbler, and a cleaner for brass in the sonic cleaner. The make many solutions for the sonic cleaner, pick what you need for your job, I'm only doing reloading.
After the sonic cleaner, I put them in the tumbler for about an hour, and my brass is completely clean, very close to new brass, even the primer pockets are clean.
That sonic cleaner is very good, but if I was to use mine for bolts, I think I'd use some brake clean to remove the grease as much as I could to keep my solution as clean as possible for as long as I could.
AllC34Me (04-07-2017)
Thanks,
Danny
But, if I was cleaning bolts like this thread suggests, I'd have some WD-40 until I was going to use them, and or paint them for use.
And, I don't think that a sonic cleaner would remove any chemically applied coating, unless you put it in for 30 minutes (or more), but a cleaning cycle only takes about 5-8 minutes.
1) Wire wheel on a bench grinder
2) Tumbler and media
3) Out source to a platter.
4) Buy new
I have done all four and # 1 & 2 are time consuming and don't always produce the desired results. #3 & 4 seem to run about the same price and again #3 doesn't always produce the desired results.
It comes down to time vs. money saved vs. desired results vs. NCRS judging. You have to weigh all the above and make the call on what's best for you.
For me on a non judged car I will make up a list that consists of all new hardware and rubber for the rolling chassis and drop that is one order. Last restoration for this option was $2,605.53
If re-using hardware you can cut that cost down to the price of a handful of rubber items and some paint. Think about it, even on a 125K mile chassis that hasn't seen the road since the mid 80's the only thing that is really bad is anything rubber. All the rest can be cleaned, repacked, re-shimmed ETC.
Not sure yet what direction I will head in on the 71 but I do like a factory fresh looking chassis with new nuts and bolts. I might do a combination of #1,2,4
D
I'm not doing bolts, I'm reloading. You might be better off to ask one of the guys that's actually cleaning the bolts.
My bad. The question was for the thread starter. However, I understand the sonic won't remove the finish but the tumbler well. so that is what I am curious with.
No problem, I don't know that I would need to tumble any bolts after the sonic cleaner. If you cleaned them with brake clean to remove the big grease, I think that sonic cleaner may do the trick. But, like you, I'll wait to see if this is true with the OP.
Senior Member
Received 2,031 Likes
St. Jude Donor '10
Afterwards I sometimes soak the nuts and bolts in an oil based product like bicycle chain lube. That penetrates the nuts and bolts and it also prevents corrosion of the parts.
Its not a perfect science but it is a lot of fun to see these nasty parts coming back to life.
David
Senior Member
St. Jude Donor '10
It would probably be just as effective once you get the grease and dirt removed. Nobody wants grease to mix in their media for sure. I don't own a blast cabinet and my back limits how long I can bend over even if I had one, so this is a set it and forget it solution for me. Allows me to multi-task.
David
David
Senior Member
St. Jude Donor '10
Hope that helps.
David
#33
Senior Member
St. Jude Donor '10
Thanks for asking.
David
#34
Senior Member
St. Jude Donor '10
Latest batch of small parts to come out of the media tumbler using Glass Bead 70 Grit.
The valve cover parts will be painted Corvette Orange and be put back into service.
The lug nuts will have their threads cleared, soak them in bicycle oil, put them aside for use on my 69 chassis later.
The mirror brackets will be clear coated and put aside for use late, as will the emergency brake bracket.
Front spindle washers, not sure yet, thinking.
Thanks for watching.
David
David
#35
I don't have a sonic cleaner and I don't handle brake cleaner typically to do this kind of work. VOC's can and are an issue. Only way I would use brake cleaner is with a correct mask in a well ventilated area. My little tumbling station is in my basement where those brake VOC's are not welcomed. I'm not saying that won't work well for anyone, I'm just saying it wouldn't be a viable solution for me.
Thanks for asking.
David
Thanks for asking.
David
And they make a brake clean for you worried folks that's VOC compliant. Look for it on the car parts store shelves
#36
Senior Member
St. Jude Donor '10
I don't know about you, but I never use brake clean spray can in an enclosed area. And I never said what kind of personal protective gear I use. I honestly thought that was a common sense thing, that we would all use it, gloves, mask, safety glasses. I guess working in and around the USAF for 42 years has me taking safety for granted, and thinking everybody else does as well.
#37
I've been stationed at bases that were closed due to contamination. I could continue, but I won't. I'm just waiting for the symptoms to show up for all the chemicals I've been exposed to. That's why I take almost every precaution that I can now, I don't need to compound what's already in my body.
#38
Senior Member
St. Jude Donor '10
I became a painter in the Air Force in early 1975, and we had little more than paper masks back then. And we painted polyurethane by the hundreds of gallons every week.
#39
Thanks for the post. I had heard about this, but with your photos I can now see that this is something that I can use. I plan on using getting one and the media at my next tool run.
kdf
kdf
#40
I picked up the tumbler this past Sunday. I already have it running with various rusted bolts nuts and washers. Its taking longer than I expected because I keep turning it off to check the progress!!. I have to just let it run for a while and leave it alone. But I can already see improvements on many of the bolts.
Thanks for bringing this up and showing the photos.
kdf
kdf
