"Blow & Glow" Fuses
"Blow & Glow" Fuses
Has anyone used, or have an informed point of view on those fuses (blade style - all amp applications) that evidently have a tiny LED light that glows if it blows? Like many of us, I've blown a couple of fuses and we all know the pain of being a contortionist that, first finding then replacing it presents. But, based on personal experience anything Chinese, especially automotive, forces me to think twice.
The concept seems brilliant (pun) and I'd like to try it. I think.
requires an additional wire - Gnd. built into the fuse box.
No Led can function without power and Gnd.
so you can't just replace a standard fuse, with a fused Led indicator.
Received 3,218 Likes
Has a resister in series with dual reverse LEDs (so you can plug them in either way). The LED will illuminate when the fuse is blown, as long as a sufficient load is still present in the circuit- that provides enough current for the LED to show a fault.
I'm using them-
Have a blown fuse wired in w/ my fuel pump roll-over /impact valve to easily show me a problem.
[/url]
And if you want to use them but have glass fuses- thus will handle the conversion-
Lakeside49 (04-07-2017)
I dont use fuses, when i wire from scratch i run breakers,
And if keep the old fuse panel in my 69 rather than any fuse i will run breakers like this,
Made to replace a glass fuse, i ran breakers on many things always worked great but like all things might not be a cats cup o tea....
I changed all of the fuses on my 86 with these. I found them at my parts store when I needed a new fuse, and ended up just replacing all of the fuses. It has been over a year now with no problems.
They won't work on my C3 because of the blade type, but I think it answered your question about if we use them.
kdf
kdf
kdf
kdf
These guys want $5/each...https://www.opgi.com/chevelle/CH30265/
Have a set of 8 glass to blade -I'm not going to be using as I totally moved and replaced my fusebox- $15 shipped.
shoot me an email richard454 at comcast dot net
My new relocated fusebox-
Jeffs82c3 (04-08-2017)
kdf
kdf
They're still a PITA to change which is why I changed over to the adapters and blade fuses shown by Richard 454
They "can"- you just need these-
Thx. Rick
