Rear brakes aren't working
Car sat all winter, of course. First drive had terrible brake. Found a caliper on the rear that was moist so I replaced it. I have bled the system and now have a low pedal. The fronts seem to work fine, but it seems the rear are not working. Would the proportioning valve cause this if it were bad?
Bleed, bleed and then bleed some morel
Same situation I had after replacing all of the rubber brake lines in the wheel wells. A helper or a power bleeder will be of great assistance. Vacuum bleeding isn't as effective as in other cars.
I went through more than a gallon of brake fluid but at least the system is very clean now (I'd done some flushing/bleeding when new to me to clean up the system filthy system but didn't have it as clean as now.)
I've gone through not quite a gallon of fluid. I am tired of bleeding brakes. . Could it be there's still air in it?
I replaced rotors, calipers, pads & rear rubber & short stain. stl. lines, AND bled the entire rear brakes BY MYSELF...started out gravity bleed, then finalized by putting jar w/ hose going from bleeders into jar to ensure all air bubbles were GONE!
BE SURE & bleed the INSIDE bleeders first (Yes, Martha, there are TWO bleeders on the rear brakes!) I've had a FIRM pedal ever since...I don't need no stinkin' power bleeder or vacuum either!!
........................................ . tom
I had given up on bleeding any more. But I gave it another go and as I was bleeding I noticed that one of the calipers that I replaced just last year was sleeping ever so slightly at one of the pistons. Got my warranty caliper and now my pedal feels like it did last year. Would have not found it if I didn't take the advise to keep bleeding. I can move on with my life as this has been a thorn in my side for about 3 weeks now. Thanks for the suggestions.
