Heater/AC air diverter door in 73
Where is and how do you access the air diverter door in a AC equipped stock 1973? It is the one controlled by a cable connected to the temperature wheel. I can't seem to clearly see it in the AIM. Pics would be a big help.
Thanks.
Fran
Thanks.
Fran
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You must remove the main heater box from the car, then remove the rear covers that hold the core in place. Once this is done you can then remove the temperature flapper door. I made the picture below for you just now, and while they say 77-82 the removal process is the same. If you have any questions post back again.
Willcox
Willcox
Blue73Shark (04-13-2017)
