whats the best epoxy?
This is an end to the 3 piece repro indy pace car spoiler. You can see it comes with one stud in one of the bosses from the manufactuer, but I want to add 2 more studs in the other 2 bosses so it will draw up tight against my fender. The part is urethane, and I'd like for the stud to not be able to pull back out over time, and like i said, I need use the stud to draw the end piece up tight against the fender. That being said, any suggestions?
Hi,
I would go to a good automotive paint store and look at the two part urethane adhesives. Talk to a knowledgeable person. Also, call Lord Fusor is a good product. I have used it to glue steel to fiberglass. Bullet proof bond. But I don't remember which one I used.
Regardless, I would test its strength after gluing whatever it is that you are gluing.
Good luck!
Good luck!
MISTERZ06 (04-14-2017)
Fusor products are good but expensive and they only sell it in large double tubes and you need a special gun to dispense it . Once the seal is punctured it has a shelf like . For what you are describing I use JB Weld and it can be bought almost anywhere and is fairly cheap . When I mount a stud I make a hole big enough for a small bolt to be inserted with the head first then bond it in with JB Weld. The head being bonded in will keep it from turning or pulling out. I never had a stud fail using this method.
Received 2,827 Likes
Crowd Plow For Now
Check with a marine store... they have products in smaller quantities
Received 3,220 Likes
I'd get one of these- many sizes to chose from -even HomeDepot carries them.
Drill a smaller hole-heat it up -then screw it in like butter- probably won't even need epoxy.
Here's what I wound up doing. I bought some of the fasteners shown above, drilled out the 2 lower bosses and installed the fasteners with JB Weld. The fasteners felt very solid without any JB Weld, but I like the extra insurance. I'll let it cure till tomorrow night, then hopefully get it installed problem free. If no problems, then the other side should be a piece of cake.
I have a 1978 with a rear spoiler, a few of the bolts rusted away. I used standard J B Weld, the dark gray stuff. I purchased a few studs let it cure overnight.
That was five years ago and I have not had an issue with the coming out.
They make two types of JB Weld . The standard and the quick set . They work the same except that the quick set has to be applied fairly fast and can be used sooner. The end result is the same . A very good fix for just about everything.
