Use a heat shield to keep your carb cooler
Use a heat shield to keep your carb cooler & prevent Heat-Soak
use a heat shield under your carb and it will keep it cooler
GM used to make them -i think they have been discontinued
they are available aftermarket or NOS
for SB & BB
they are available for Quadra-Jet and Holley carbs
....................... tom
https://www.summitracing.com/parts/hly-108-70/overview/
http://www.ebay.com/itm/ROCHESTER-QU...NXn9rW&vxp=mtr
http://www.ebay.com/itm/1964-1972-GM...tY7X9k&vxp=mtr
http://www.ebay.com/itm/1964-1972-GM...BYRyjm&vxp=mtr
http://www.ebay.com/itm/1967-75-GM-A...1XT24Q&vxp=mtr
for SB & BB
for SB & BB
for SB & BB
Received 2,878 Likes
Hi,
I believe the shield was used under the carburetor on engines in cars to be delivered in California during the 1970 model year. (?)
Regards,
Alan
Regards,
Alan
Primoz (09-26-2022)
Good article/read about Heat-Soak - and how it effects your carburetor
with the new fuels and when your car sits after reaching operating temps and hot weather, your Corvette might be a little hard to start
........................... tom
http://www.edelblog.com/tech-tips/resolving-heat-soak
BBCorv70 (04-15-2017)
Wouldn't a thick carb gasket accomplish the same thing? Isolating the metal of the carb from the metal of the intake would prevent heat transfer. That looks like a piece of aluminum. And to quote your post..."GM used to make them". Got to be a reason they don't any more.
That being said, I think airflow in the engine compartment would be most important. I mean, if you put your carb in the oven and set it on 450 degrees, it's going to BAKE. Leave the oven door open and point a fan at it, and it'll just toast a little.
Just asking. I'm no expert.
MISTERZ06 (04-17-2017)
an Insulator will work just fine without the sheild,
shield will help more, but they do get in the way.
just installing a 1/4" gasket/insulator stops the block heat from transfering into the carb.
dropping the temperature of the carb. almost 100 degrees.
I measured temp. before and after, after adding an insulator to the carb.
my carb. had cold condensation on the outside after warmup and running.
It literally was colder that outside tempature, just by adding the insulator.
This testing was completed by also blocking the exhaust cross over ports under the carb..
It is a must have item in warm geographical areas.
MISTERZ06 (04-18-2017)
There is a good chance the fuel is boiling in your fuel line. When you encounter the hard start issue grab your fuel line and see how hot it is.
Anyhoo.... I solved my hard start issue be insulating the fuel line with Heat Shield Products Fire Armor 210040 Sleeve. It will cost you under $20.
I also found that using ethanol free gas helps with the issue. You can install the free app "Pure Gas" on your smart phone to find who near you sells ethanol free gas.
for SB & BB
for SB & BB
No, they have NOT been discontinued by GM. The part number has been superceded 3 times, but they are available to order from any GM dealer parts department. Part #10069984. May take a few days since the only GM parts warehouse that has them is Memphis. Here's a link that shows the carb insulator/gasket: https://www.summitracing.com/parts/ado-216-82
By the way, I do indeed have one on my Vette.
