73 T-Top 7000 miles
You are right in one respect about the wear on the front tires, however you could not get B.F. Goodrich Radial T/A's on any Corvette back in 1973.
Undercoatings sprayed on at the dealers were spotty at best and can't be a reliable indicator in many cases.
That is my point. With only 7000 original mile on the car the tires have been replace at some point and show signs of significant wear. I would check the manufacturer date on the tires, measure the tread depth and try to determine how many miles were put on these tires from the date of manufacture. It could help to determine how accurate the odometer reading is. Or it may not.
I have faith that this car is true for the low miles. It has rusted parts just like it should be at that many miles, age and exposed to the normal atmospheric conditions.
