Pulling to one side when braking. Caliper leaking
I have a 72 vert. It been pulling to the right when braking. I notice the car is fine when it's cold. After about 10 mins it starts pulling.
I have lifted the left wheel up and spun it and had my son press the brake pedal. The wheel stops spinning. Seems fine.
I took the caliper off the rotor and cleaned the pin on top, the backs of the pads and any grease thinking something may need to be cleaned and regreased.
When I push the pistons back in a little fluid will leak out of them. Does this mean I've broken the seal?
I sucked out the silt in the bottom of the master reservoir.
...made sure the fluid didn't get down too low
I just had the entire brake system redone 2yrs/2,000 mi ago. I would take it back to the shop but the guy got mad at me for bringing my car back a few times because the steering and rear end were leaking and I kept bringing it back. So going back to them isn't really an option.
Main question: should I get a new caliper?
Dave
Dave
If you have a caliper that's leaking, then you either need to replace it, or replace the seals.
Was there brake fluid on the rotor or pads, when you removed the caliper, and/or is there brake fluid on the back side of the tire? If the rotor was dry, and the tire is, then your problem may lie elsewhere. Where the brake hoses replaced, when the brakes were done two years ago? If not, you may have a bad hose, that's collapsing under pressure, causing one caliper to get more pressure than the other.
I just went through this with my 79. I wound up just replacing the caliper with one from NAPA, lifetime warranty. I also replaced brake hoses and put new pads on. I first tried to replace the seals on my existing caliper, and that was a colossal failure. Not sure what I did wrong, but decided to bite the bullet and pony up for another caliper.
"When I push the pistons back in a little fluid will leak out of them."
Yes, you have a bad seal and will likely need to rebuild or replace the caliper. Sometimes you can get them to reseal but it won't last long.
Leaking calipers is an Achilles heel for the C3, especially if it sits for long periods. How is your brake fluid level? If it's dropping you have a leak. The car will pull to the side that is not leaking as the brakes are not grabbing evenly.
I second the Autozone route. I bought new calipers for my 82 over fifteen years ago...can't beat lifetime warranty; buy 'em once! I also have the counter guy pull several boxes, I look through them until I find the one with markings (Delco Moraine), etc that match.
It ended up being that it needed to be bled.
The caliper wasnt leaking until I started taking stuff apart and trying to figure out of these old school calpiers function.
I determined this because the pads werent all eaten up like other photos I saw online of other peoples C3's with leaking calipers.
Pulling to 1 side can be a number of things.
As the brake pad temps warm up they start to build the proper friction required to work correctly. Once they are up to temp the following may cause pulling to 1 side.
1. less friction between pad and rotor on 1 side. (possible contamination on pad or rotor) Sand the rotor to remove any deposits.
2. brake pad bedding procedure was not done. or the brake bleeding had air in 1 side during bedding of the pads.
3. You have worn steering / suspension parts and something is changing the alignment under braking.
4. You still have air in the system on 1 side and require bleeding.
5. Your rotor run-out is high on 1 side which will pump air into the caliper and over time produce the same effect. re-bleeding the brake will correct this for awhile.
Primoz (05-28-2017)
