427 Starter - 2 hole or 3 hole nose cone?? - CorvetteForum - Chevrolet Corvette Forum Discussion
C3 General
General C3 Corvette Discussion not covered in Tech
Old 05-19-2017, 05:57 PM   #1
bigredbrad
CF Senior Member
bigredbrad's Avatar
Location: Lincoln NE Riding and Driving Corvettes since 1967.
Default 427 Starter - 2 hole or 3 hole nose cone??
Spent 2 hours searching forums, Colvins book, NCRS TIMJG, ebay and Im still confused on which starter nose cone is correct.
I currently have the "wrong" starter number with a 2 hole cast iron nose cone installed and starting the car just fine. I want to purchase the "correct" date coded starter to replace it with. My original 427 block appears to have 3 threaded holes for a starter to bolt on, but all my searching does not say if the 3rd hole is used or not.
Here are 2 pics of starters that should fit a 427 in 1968. Other than the Delco number stamped on the starter case, which nose cone is correct both in appearance for judging and functionality for driving?
thank you,
bigredbrad
bigredbrad is offline   Reply With Quote
Old 05-19-2017, 07:55 PM   #2
sug
CF Senior Member
sug's Avatar
My l68 has cast iron two hole like your first pic .
sug is offline   Reply With Quote
Old 05-19-2017, 09:15 PM   #3
bj1k
CF Senior Member
bj1k's Avatar
I'm pretty sure the three hole starter is a universal starter to be used with two different flywheel sizes.
bj1k is offline   Reply With Quote
Old 05-19-2017, 10:39 PM   #4
sullyman56
CF Senior Member
sullyman56's Avatar
My 68 L36 has the two hole starter too.
sullyman56 is offline   Reply With Quote
Old 05-19-2017, 11:15 PM   #5
bigredbrad
CF Senior Member
bigredbrad's Avatar
My engine block has a third threaded hole that looks like it would line up with a 3 hole nose cone. Just hate to buy a 3 hole starter to get numbers matching and find out that it is not correct.
bigredbrad
Old 05-20-2017, 12:49 AM   #6
CanadaGrant
CF Senior Member
CanadaGrant's Avatar
Quote:
bigredbrad
My 69 L36 also has the 3 threaded block holes but the stock starter is the 2 hole offset bolt pattern.
CanadaGrant is offline   Reply With Quote
Old Yesterday, 09:08 AM   #7
bj1k
CF Senior Member
bj1k's Avatar
I know that GM used one flywheel that is smaller and it used the two hole starter that had the holes straight across from each other used on 6 cylinder engines . But all of the corvette small block engines that I have seen take the two hole diagonal pattern . Not familiar with the big blocks though .
Old Yesterday, 09:23 PM   #8
Big Don
CF Senior Member
Big Don's Avatar
I just replaced the starter on my 69 427 4-speed with a rebuilt correct one from Zip. There are 3 mounting holes on the engine, but only 2 on the starter, and they are on a diagonal. All works fine now, but it's a hell of a difficult job if you don't have a lift. Also, take photos of the wiring before you take out the original one.
Big Don is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • 427 Starter - 2 hole or 3 hole nose cone??
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    FS: Black Driver Side Headlight Assembly freaknbigpanda C6 Parts for Sale/Wanted 2 03-02-2017 09:44 PM
    FT or FS Chrome Spyder Wheels patron1992 C6 Parts for Sale/Wanted 7 02-11-2017 01:08 PM
    05-08 Kooks off road X pipe BunnyBoy C6 Parts for Sale/Wanted 1 05-04-2016 05:38 PM
    Can i use Royal Purple Synchromax Manual Transmission/ differential fluid in a C6 Z06 tizzee11 C6 Tech/Performance 4 03-06-2016 12:22 PM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
