75 Coupe convert rear window to removable
Received 1,308 Likes
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
I'm pretty sure this has been done many times. I just started researching what's involved in converting, and from what I've read (older threads and posts) the required parts must be gathered vs. purchased in an all in one kit, but the info is vague and not very explanatory- at least I do not follow it. The word I hear that's used to describe the job is "doable", but what does doable mean? Is it a big deal to do this conversion, and are the parts easy to come by? Thank you
I reto fit one in my 76. Easy to do and all parts are avail.The only thing is the rear window frame is not repoduced I found mine on E bay. Once you pull the interior pieces off you'll see where the latches in the early C-3's mounted cause its still there.
cor66vette (06-19-2017)
The glass will not fit the frame. Usually you can buy them w/the original glass.I send you more info via PM...
I have a rear window out of a 1970 I'd sell for $50 plus shipping. The frame is in great shape but the glass is badly scratched. I'm guessing shipping might be a little pricey. The window is located in Salt Lake.
It's a fairly easy conversion. Only messy part is the seal.
I have some pictures in my build thread.
You will need window with frame, with the pins on the bottom. Two receivers, that mount in the lower edge of the opening. Two latches that mount in the roof. And a new seal for the opening. And lastly, the "halo" panels, or do as I did, and cut Yours. All the screws and nuts can be found at your local hardware store.
Best upgrade I've made. No more ice-cream hitting me in the back of the head.
https://www.corvetteforum.com/forums...-on-storm.html
Have a Great Day,
Bill
Have a Great Day,
Bill
cor66vette Killer price for frame.. snap it up!!
Received 2,878 Likes
Hi c66v,
The 68-72 cars with the removable rear window had a 'storage tray' that the window sat in while it was out.
It's hinged and fits up under the rear deck quite closely. It keeps the window out of the way if you have 'things' in the rear compartment… like the roof panels. You might consider looking for a tray if you think you might find it useful.
The removable window is pretty 'cool' in several ways.
Regards,
Alan
Regards,
Alan
The following 2 users liked this post by Alan 71:
cor66vette (06-19-2017),
patg84 (02-04-2020)
Thanks, Alan. I've read about the tray. Seems like something handy. I can add that once I complete the actual conversion. I can see already this project adding up $$$.
A '77 or older was a "must" in my search for a 'Vette for this very reason. I got everything(including a sawed-off piece of roof)from a member here for $500 I believe, without the tray. Probably about the going rate. I got a good deal on the tray, but I have seen them fetching up to $500 alone, I guess because they can deteriorate. I don't consider the tray a must; you could fab something up and save some $$$.
Hi Richard and c66,
The tray used from 68 through 70 (and perhaps into early 71) production was made from 'black flocked' fiberboard. They were easily damaged if the rear window leaked and so have become rare ($$).
The trays used for most of 71 and 72 were made from fiberglass and have survived well so are more reasonably priced.
If you decide to install a tray be aware that the hinges each require a re-enforcing plate in the rear bulkhead and the clip or button release requires a nut plate in the fiberglass below the window.
This might deter you from adding the tray… and you can certainly live without it.
Regards,
Alan
A fiberboard tray. Note the clips to hold the window in place.
An example of the material used in the later tray.
Regards,
Alan
IMO no need for the tray.Save $$$ Window stays put just fine due to the wheel wells ,does not move.
Finished look with weatherstripping
