'81 w/battery light (gen light)
I've done some thread searching as well as googling, and I'm stumped. At this point everything seems ok, but the battery light is on while driving. What I've done:
New battery - the old one had gone dead from lack of use one too many times, had it on a battery charger for a few days and never fully charged.
Replaced the choke relay - it was buzzing and the choke light stayed on. I really thought this would fix it based on other threads. Choke light no longer stays on and the relay isn't buzzing.
Pulled the center console and inspected the PCB. One of the connectors was tweaked causing oil pressure to be pegged to the right. I smoothed it back then super glued down all the ends where the plug connects just to keep everything straight while reconnecting. Oil pressure gauge fixed.
Voltage across battery when car off is 12.7. Voltage when car is running is 14.1 - doesn't matter if at idle or rpms are up.
What am I missing?
What am I missing?
I believe the Gen Light refers to the alternator. Mine was doing something similar and I pulled the wires connected to the Alternator and and reconnected them better and it fixed it.
I would love to know which wire was tweaked for the oil pressure gauge that fixed yours, mine is doing the same as yours was, always to the right.
Pegged to the right means open sender. Disconnect the sender and ground the wire. This should make it peg to the left. If it does replace the sender.
What am I missing?
What am I missing?
I'll double check the connector at the alternator itself, then I'll drive around and try to pay close attention to how dim/bright the light is and what makes it go dim/bright. I don't have a FSM, just a Haynes manual. I try to avoid working on my cars now, any real mechanical work I'll take to a shop.
Check the Choke heater fuse and relay. I know it sounds silly, but the choke heater also supplies power to the exciter (brown wire) in the alternator.
I actually replaced the choke relay already - it was buzzing and the choke light would stay on or flicker. I really thought this was the issue, but choke light is fixed and batt light isn't. I didn't check the fuse though, I'll add that to the list. I took it out to lunch and really paid attention to the light, maybe more details will help:
- At idle the light is very dim, it almost looks like it's off, you have to look closely. This is T-ops off in the sun, so maybe at night it's more obvious.
- It gets brighter as RPMs rise. Not full on bright, but definitely brightens up with RPMs.
- It flashes brighter with turn signals.
- Turning on headlights gets it to nearly full bright, considerably brighter than anything else mentioned.
Here is what the manual is showing for Gen Light on while Engine is running. There was also a note for battery being undercharged will cause this, you just replaced the battery but if the alternator is not charging it effectively it could cause.
Thanks for that. I haven't driven much at all since replacing the battery, just short jaunts, so I connected my trickle charger.
Not sure how helpful that page is, but thanks for posting it. Once I've ruled everything else out and I'm really at step 3 I may as well just replace the alternator. It's probably the original and I just don't want to go digging into it hoping I get it back together correctly to save $80 or whatever.
The kicker is I'm seeing 14.1 volts at the battery with engine on so I've convinced myself that the alternator itself is ok.
Yea, Alternators aren't to bad to replace price wise. That is what the dealer would of done if you brought it in to them back in the day, it's from the GM Chassis Manual. Of course unless you are the 1st owner who knows what has been done since then with the wiring, aside from age.
Well, that page doesn't take into consideration things like the choke relay/fuse, bad wiring connections, problems with the PCB and who knows what else. All those weird things that happen with a 35 year old car that people figure out over the years.
Step 3 is an easy one- touch that tab on the regulator to the case with a screwdriver and it puts the alternator into "FULL OUTPUT" mode.
Right - but once you start following step 3 you eventually get to "replace voltage regulator" or "repair generator." The decision tree doesn't lead anywhere else. This gets me back to where I'd rather just replace the whole thing than take it apart and try to fix it.
With battery fully charged via trickle charger, no difference.
~14.4 at plug, doesn't change with RPMs. ~14.6 at main big red wire, doesn't change with RPM. With lights on, the load that seems to make the biggest difference with the batt light, voltage drops roughly 0.1. Initially turning on the headlights does appear to cause a bigger drop for a fraction of a second - my meter drops then almost immediately levels back out.
I personally would open it up and do more tests and just replace what is needed, but that's up to you.
I'm not sure how to test max amps. I suppose I can put a load on the system then check amps at the battery, but I can't max out the system. My A/C didn't work when I bought the car back in '94, and I never bothered to fix it - pretty much t-tops off nice weather driving only. Otherwise I can just do lights on, wipers on, radio on, turn on flashers...
Then there is the issue that I don't know what I'm looking for. I'm guessing it's a 70amp alternator??? What amps would I be looking for?
Took it to autozone and had them test it. I'll be the first to admit I don't trust them 100%, but they hooked up a special piece of equipment and ran it through a series of tests - starting with the battery, through the startup, checked charging, tested voltage, diode testing, and finally amps under load. Passed all checks.
What am I missing?
What am I missing?
What am I missing?
What am I missing?
