White spark plugs
St. Jude Donor '17, '19
White spark plugs
Hey Guys,
My 1980 has been starting to put out whitish exhaust smoke, but I don't notice oil missing.
I pulled a spark plug and the tip is white. I was told by a friend this means it's running lean and can also cause the white exhaust.
Suggestions of where to begin to get this running correctly again? Tune the carb?
Thanks.
Thanks.
Sounds more like coolant in the cylinder(s). Does the exhaust has a sweetish odor (assuming you have antifreeze in the radiator)? Or does it have a noxious, eye watering odor? The sweet odor would be coolant turning to steam during the combustion process. The noxious odor would be unburned fuel, which is what you'd expect from a mixture lean enough to "white" a plug.
How do the other plugs look? Any other associated issues like overheating, coolant loss, poor engine performance?
Eyes water and burn, and smells like exhaust, not sweet.
Received 3,043 Likes
St. Jude Donor '05
sounds like its running real lean
like the above posted said ck the other plugs and compare
Is it stock, what changes have you made?
does it surge at all at cruise rpm or "trailer hitch"/feel real down on power?
https://www.summitracing.com/parts/a...SABEgL7WPD_BwE
These will tell you what your engine is doing so if its rich or lean very easy to troubleshoot many different versions. Uses an 02 bung just make sure there are 0 exhaust leaks upstream.
I haven't checked the other plugs. Just the one. But I can do that if you think it is necessary. I figured if I was seeing the exhaust and it was hurting my eyes, checking them all wasn't necessary as I know I have an issue.
No mods, its the original engine. Rebuilt 40k miles ago according to owner I bought it from.
No surging, but sometimes it idles high when I push in the clutch. And wont' stop without driving it for a bit.
I haven't really noticed it lacking in power, but it is a 1980. I thought it was a little sluggish since I bought it for a v8. Government regulations had these down to 180HP or something stupid like that.
I would check the oil for a gasoline smell. Chevy engines were famous for defective fuel pumps that would let gasoline get into the oil pan when the seal goes bad . It thins the oil and can destroy the engine in a short period of time. You would see a lot of smoke coming out of the exhaust . If you smell gasoline , flush it and add clean oil and filter before starting the engine .
If this is a recent development and you factor in your high idle issue, it could be a vacuum line has broken or come off either contributing or causing your lean condition.
A vacuum issue would cause this? I didn't realize the vacuum was part of the air flow for combustion.
Vacuum for you cars systems comes from below the carb, basically the intake manifold.
So the more air that is allowed into the intake manifold without going through the carb makes the overall mixture leaner due to the fact that it didn't pass through the carb and pull fuel as it entered the manifold.
I would look at the cat .they were bad when new .replace with new better flowing .or you could open up what you have .then check to see what it smells like.
I had a 1 ton pickup long ago that after I put a set of headers on it, the exhaust and plugs started burning white. I was told that the better flowing exhaust caused the mixture to go a little lean.
If it was fine before and now it's not and you haven't changed anything then something has changed of it's own accord. A vacuum leak is something that can develop over time. It could be a hose or the actuator on an item.
If you have made a change and this started occurring, then that change is likely the cause of the condition.
Too little fuel for a lean condition
concerning the white smoke, have you been keeping an eye on your coolant level to see if it is gradually going down. If it is get a a coolant hydrocarbon test kit to verify you have a possible internal leak, head gasket.
