Is Holley 600 CFM too much?
Hello
I have a new 350/290 HP chevy and I bought Holley 600 CFM STREET WARRIOR CARBURETOR. The mechanic said it too much for the car
The engine
https://www.summitracing.com/parts/nal-12499529
The Carb
https://www.holley.com/products/fuel...parts/0-80457S
is it possible to adjust it?
he said it's just better buying a lower CFM rochester carb.
Q do I buy a 400 CFM? any suggestions??
I need a part number if one of you have something in mind.
The engine
The Carb
Hello
The engine
The Carb
The engine
The Carb
Ariba - Get a new mechanic.
600 CFM on a close to 300 HP SBC is a little low in my option but this could be a long, drawn out conversation.
BTW the "lower" cfm Rochester is 750CFM.
ariba (04-27-2018)
I've see lesser engines work very well on a 650 Holley DP. A 650 would have been my choice.
A 600 would be too much carb for a lawn mower, not your engine. Can you tell I don't like a 600 cfm for a 350.
A 600 will work well, however you're not getting the full potential from that engine.
Received 3,043 Likes
St. Jude Donor '05
Its fine
You might want to think about finding a new "speed shop" guy...
A 600 Holley will work great.
As others said, I would probably have gone somewhat bigger. You will probably need to change jets to maximize performance (if you want).
I have a 670 Holley Ultra vacuum secondary carb and I love it. My build is somewhat mild. I get great mileage and power when needed.
Sounds like the speed shop wants to sell you a carburetor. Stick with what you have and tune it to your engine.
I really trust him he dos't have a carb and he asked me to buy from any palace even online.
Just updating
Called Holley and called summit and both gave me different opinions.
But there is a big possibility it's the fuel pump is sending more than 8 PSI
So I bought two thing so either one of them work
First: Fuel Pressure Regulator
https://www.summitracing.com/parts/sum-g3032b
If it didn't works
Second: Two different sizes of Holley Standard Main Jets
https://www.summitracing.com/parts/hly-122-60
https://www.summitracing.com/parts/hly-122-62
gasket
https://www.summitracing.com/parts/sce-358
BUT it's a big possibility it's THE Fuel Pressure Regulator
If it didn't works
gasket
I think this video will help!..
It was the
the fuel pump sending to much FUEL
Solved it with a Fuel Pressure Regulator
The Vette is running Great ......
Update
It's a Shame that you rely on mechanic word, especially when he told me the fuel regulator solved the problem and its working fine. The body restoration just finished a few days ago so there wasn't time for me to check the Carb worked fine or not.
Now the problem
when you start the car you need to step on it and raise the RPM or it will shut down. You have to wait until it gets worm 2-3 min.
The fuel Regulator is 4.5 - 9 psi.
Now the problem
Your mech sounds like more ego than knowledge, sadly a lot are like that,
I 600 is kind of the plug and play out of box carb,
My mild buick 6 v ran great on it,
Im no fan of over carbing but a 600 on a v8 over 300 ci is marginal unless just a cruiser math might not say it but a dyno will......
Update
Now the problem
Now the problem
My carb is not equipped with a choke in any fashion- I have to play with it until it gets warmed up a bit too.
Sounds like the floats aren't in adjustment. That's what I would check first. Possibly not enough fuel until the pump fills the bowls.
Then again a choke problem is possible. The Holleys need tweaking on fast idle speed.
And 600 cfm is fine.
I ran a Holley 600 dual feed, dual pump on a 400/TH400 in a GTO. People said it was too small, wouldn’t work with an automatic. Ran well enough at the strip to throw a rod through the block at 5800 rpm... Best throttle response I ever had from a carbed car.
If you can afford it. Look into the Holley Sniper EFI unit. Takes all the worry out of the situation.
ariba (04-27-2018)
