Rear suspension rebuild.
I am trying to get together a list of everything I would need to get to replace all the hardware and bushings on my 72 big block. I will probably won't need anything for the trailing arm as I will just get rebuilt ones. And the strut rods would be the adjustable ones so I won't need those bushings. i will also need u joints and all that hardware.
I know they make a hardware kit but I haven't seen a bushing kit with the hardware. Thanks guys.
you already stated you are getting the TA rebuilt and are using new strut rods so the only thing left are the rubber biscuits on the spring bolt and the shock absorber lower bushings. If you have a rear sway bar you need those bushings also.
Plus u joints, all hardware for the rear and half shafts.
