I regret buying GM 350ci/290
A 3.73 rear is on my bucket least but what's the difference between 3.55 vs 3.73
I'm pretty sure Super Chevy magazine did a build up of the 290HP crate engine a few years back, and as I recall, for not much work and $$ they got some impressive gains out of it. You might try a google search and see if you come up with anything.
ariba (09-24-2017)
Received 3,043 Likes
St. Jude Donor '05
switching from 3.55 to 3.73 will feel about the same with a very slight difference in cruise rpm. imo not worth the effort or money
http://www.wallaceracing.com/calc-gear-tire-rpm-mph.php
This the article you were thinking of?
Got curious because I am also thinking of getting one of these motors.
ariba (09-24-2017)
St. Jude Donor '05
just blows another myth out of the water that a modern can and headers do make a noticable difference. Tomorrow youll see someone say old GM stuff is about the same.
Do a Vortec head swap and a modern cam....I'm not sure you'll gain 70hp, probably more like 40-50hp but it will wake it up all across the range. You'll need the vortec style intake also. You won't be doing this all for $1000 but, I bet you can get close if you are deal saavy.
The GM crate 350 heads are based on the old 882s and there is nothing you can do to make any power with them.
I'd find some small chamber Vortecs, use a steel shim head gasket and try to get the compression as close to 9.0 as you can from your dismal 8.5.
Maybe an XE268 comp cam or something of the like. I think you could make an honest 350 crank HP if you do your homework.
ariba (09-24-2017)
I really beg to differ on the 3:55 to 3:70 gear change. My car originally had 3:55's and I had to slip the clutch a lot to get it started every time. With the 3:70 gears, I just let out the clutch and she goes! The 3:55's are better if you are going to be doing a lot of freeway driving. The 3:73's will really improve your leaving the line. And yes, I heard the same story that there wasn't a big difference in the two ratios. They were wrong. Lou.
ariba (09-24-2017)
ariba (09-24-2017)
http://www.hotrod.com/articles/35029...great-part-1/#
1 cam set
2 heads
3 intake
but it you are doing all of this it's better do do an engine from scratch.
#33
I'd find some small chamber Vortecs, use a steel s matchim head gasket and try to get the compression as close to 9.0 as you can from your dismal 8.5.
and a2 matching intake
3 280 magnum comp cam kit SK12-212-2
do you think I will get more? than 50 HP??
#34
You are right It's a good engine but sometimes people are a little greedy and I think I am one of them. But in the same time I felt the other deal for the Blueprint is a better one.
ariba (10-07-2017)
