Battery drain and side mirrors
So, battery died twice (Walmart Maxx). Just inside 3 year replacement warranty, but Walmart said they had to recharge it before they would replace it. Phoo!. So bought a new battery from Advance Auto, good deal, $180 battery for $100 out the door. Four days later, its dead also. Take to a top rated auto center and they run drain tests on it and determine have a somewhat significant drain but would need to do more to determine exactly where drain was coming from. Finally determined a "red wire on the fuse block that went up into the dash and went to both sides". Disconnected wire from fuse block and no drain. Could not determine at the time what the "red wire" was for so elected to just disconnect it. All well. Radio works, alarm works - both of which were suspect. On way home and wanted to adjust side mirrors and, guess what, neither worked. That is where the wires went to - the side mirrors. I can handle manually adjusting the side mirrors, but wonder what was causing the power draw by the mirror motors. If its an easy fix, will re-connect the power to the mirrors and apply the "fix". Otherwise, will just leave as manually adjusted.
there is no power at the motors unless you use the switch so that maybe a good place to start.
This is exactly why Wal-Mart wanted to charge and test the battery first. If the battery was still good and only discharged by a drain why should they warranty that?
In our shop we have to get a failed print out code from the tester before submitting for warranty. Otherwise we eat the battery.
In any event it good to hear you found the source.
Don't take this wrong, but don't you own a car battery charger?
Not being snarky - just a serious question.
You'll find one of your mirror switches is bad. Likely the side you have to keep readjusting.
-W
So now you own an extra battery? (I trust you didn't just leave Wal-Mart a "free battery".)
-W
-W
Did not have to keep adjusting the mirrors. Only time I would need to adjust them is if I knocked one of them out of alignment when washing/drying the car. Adjustments happened maybe once every month or three. That is the strange thing as to why suddenly causing a battery drain. Did have to adjust the driver mirror about a week before problem occurred. Does one adjustment of a small amount result it this problem?
Your response isn't snarky. Sometimes descriptions of what is wrong are not complete enough.
