Floor jacks and '75
Old Sep 19, 2017 | 06:44 PM
cor66vette's Avatar
cor66vette
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
Default Floor jacks and '75
Should windows be up or down, doors and hood shut tightly or left loose, and t-tops on or off when using floor jacks to jack up a 75? Thank you.
Old Sep 19, 2017 | 08:13 PM
revitup's Avatar
revitup
My tops are off, doors closed, windows down, pretty much every time, just because that's how my car is, usually. I don't give it a 2nd thought. I just use two floor jacks if I'm putting it up on 4 jackstands to jack it evenly side-to-side. I think if doors open or closed, windows up or down, or whatever, makes a difference, the car has other problems.
Old Sep 19, 2017 | 08:42 PM
cor66vette's Avatar
cor66vette
^ ^ ^ Thanks for that. I've never given it a second thought, either. I came across an article and read a few comments that gave me reason to second guess.
Old Sep 19, 2017 | 08:45 PM
samuel082799's Avatar
samuel082799
When i jack up my car i dont do any of that stuff, the one thing i have noticed is if you jack up a rear corner the hood gets pretty close to the body. if you are doing work to it i would assume the front or back is up which wont be a problem. If it is just to change a tire I wouldn't worry about it either.
Old Sep 19, 2017 | 10:05 PM
cor66vette's Avatar
cor66vette
Originally Posted by samuel082799
... If it is just to change a tire I wouldn't worry about it either.
It's kind of like that. I'm repacking the front wheel bearings.
Old Sep 20, 2017 | 12:27 AM
samuel082799
You can use a jack stand and set the car on the lowest height. I have been restoring my rims one by one so i have the wheel of for weeks at a time. I found a block of wood that is like 3x8x12, and i set that under the frame with the 8 inch being the height and drop the car and it is at ride height.
Old Sep 20, 2017 | 12:32 AM
samuel082799
can you post a link to the article
Old Sep 20, 2017 | 08:38 AM
croaker's Avatar
croaker
My transmission shop and a tire store around here freak out everytime I show up. They must have read that article too
Old Sep 20, 2017 | 09:38 AM
raydog9379's Avatar
raydog9379
I just unlatch the t-tops which makes them slightly looser, because someone mentioned that they cracked the paint on theirs by jacking up. I have nice paint so I don't want to risk it.
I did notice a very tiny bit of flex in the gaps on the doors (gaps appear closer/further depending) when I jack up one side at a time. So what I do is go up a little bit and put a jack stand, then go to the other side and throw a jack stand. Then go back to 1st side and jack up more then raise jack stand and then to the 2nd side....
To Floor jacks and '75
