True Dual Exhuast For My 79
Looking for info on a dual setup for my 79 L-82 4-speed..no cats. Seems to me there used to be a lot of them around but I can't find much out there now. I can probably use my existing mufflers as the car only has 42 K on it and it's been inside for years. I want something that's going to fit without a lot of modifications. Any suggestions or advice?
You could use a set like this https://willcoxcorvette.com/corvette...-79-aluminized
I used something similar on my 76 but with mufflers and it will add heat under the floors. I'm going to side pipes later this year or next year.
I just went through this on my '81 and ended up purchasing the Pypes kit.
https://www.summitracing.com/int/par...model/corvette
Don't forget the exhaust hanger that installs under the trans on a 4spd. Purchased a system from Corvette Central with no modifications.
I put straight pipes on my wifes 79 and resonators at the end(Mid America). Any muffler shop could do that for you. Not noisey(compared to my 69 427 and Hookers).
