I found the source of my parasitic battery drain.
Old 09-23-2017, 08:06 PM
Plain_white_t_tops
Plain_white_t_tops's Avatar
Default I found the source of my parasitic battery drain.
I took my 79 l-48 to my mechanic for a tune up, he discovered that the op wired the choke hot to the battery. After he hooked the wired up through the ignition, the drain is now gone.
Old 09-23-2017, 08:09 PM
raydog9379
raydog9379's Avatar
Heck of a good feeling isn't it? I'm with you, had a couple things draining me out for years... used to just disconnect the neg. battery and reconnect every time I drove. What a PITA. Thanks to the forum I fixed the issues this summer (bad courtesy light board, and a bad buzzer were my issues).
Old 09-30-2017, 11:48 AM
Plain_white_t_tops
Yes it is a good feeling. He also cured my slow cranking after my car had been driven for a while.
To I found the source of my parasitic battery drain.
Quick Reply: I found the source of my parasitic battery drain.
