Tricks for 70-72 heater control removal/install
I need to remove and redo this. PO would try to replace cigarette lighter without looking, and burned several spots along the control wheels. Plus, it needs to be repainted. etc.
Any tips on removal? Least trauma to console, cables, etc.? Tips on reinstall?
Disconnect the battery first??
You need to disconnect the Bowden cable at the right-forward corner of the heater control head before trying to remove it. There are also vacuum lines on the left side that need to be tagged and pulled. You can find the electrical connections and the lamp/socket.
Then (I think) you can remove the 3 screws from the mounting frame, twist the head so you can remove that metal frame and pull the head.
Received 1,468 Likes
Cruise-In II Veteran
FWIW: it might be easier to remove the controls and the console as a unit. Remove the console trim screws, disconnect the bowden cables at the vent doors, disconnect the fiber optics harness, and disconnect the HVAC connections. At that point, the console should lift up and out.
Received 2,878 Likes
Hi Mike,
Very pretty.
I think I'd disconnect the cable at the hot/cold door on the heater box and remove/replace the controller with the cable attached at the controller….access at the flapper door is good….might be a little easier.
Regards,
Alan
PS: Have you been doing any tracking of the info on the metal tags attached to the bottom of seat springs? Specifically the Julian date codes.
ARE the last digits Julian code?
Very pretty.
Regards,
Alan
Alan,
I am convinced that is a Julian date. I have tracked them in about a dozen 70-72 cars, and they certainly seem like Julian dates to me.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If you want advice on how to rebuild the control.. go read this..
http://repairs.willcoxcorvette.com/w...ol-rebuild.pdf
