Parking brake handle replacement
Does anybody have pictures of how to remove and replace the parking brake handle? There is an old thread, but the pictures are no longer available. Thanks in advance!
here's a thread with a picture showing the most difficult part, the screw at the back of the console which is reached through the compartment where the jack is stowed. The two side screws you should be able to remove by pushing down on the seat.
https://www.corvetteforum.com/forums...ke-handle.html
did you release the tension on the cable by going under the car and loosening the adjustment at the equalizer? Once that is done you remove the 4 bolts holding the parking brake down and disconnect the cable.
Received 2,878 Likes
Didn't know you could replace handle only. The black bakelight on my handle is cracked so I bought a new handle. Thought I needed to replace entire handle.
Hi,
I still don't understand what you bought or want to accomplish…. replace the handle (chrome and black), or the handle and ratchet mechanism
What did you buy?
Regards,
Alan
What did you buy?
Regards,
Alan
Mick42767 (10-10-2017)
