Recommend reliable radiator for 1977?
I have had three radiators put in by my mechanic spring massive leaks within a year or 2 of installation. Can anyone recommend a reliable brand I can get to stop this madness? I have a Stewart hi-flow water pump installed. Looking for a 4-row.for automatic and AC. Thank you!
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,331 Likes
80-Vette (10-16-2017)
Former Vendor
Check this one out
I bought one from AutoZone 12 years ago and installed it in my 77. It's never leaked and never overheated. I probably just happened to get a good one.
Received 3,043 Likes
St. Jude Donor '05
Wonder if you have some cyl pressure working its way into your cooling system, you shouldnt have that issue
Did it do this prior to your waterpump change?
I had the pump done way back and the radiator at that time lasted a long time. The failures are more recent replacements.
Thank you for the replies and suggestions. I will probably go with a DeWitt. I've had this car for 20 years and the radiator is the weakest link over the past 6 years (AC compressor also seems to fail more than it should, but that's a minor problem)..
