How to end Armor-All?
Anyone having trouble with Armor-All all over their interior, causing fish eyes and interfering with paint and dye application? I've been running into a HIUGE problem on my newly arrived Vette with regards to Armor-All saturation of every single surface through out the interior. Honestly like someone hosed the interior down with this stuff.
Obviously as these cars age and end up in the hands of their saviors, there are going to be a lot of crap that FPO did that needs correcting, but STILL . . . ! ! !
I just recently purchased a good used shift console top plate, took it all apart for stripping and re-painting and nothing by fish eyes ! Somehow it ended up with Armor-All even on the bottom of the ashtray cover. I mean, come on !
So, how do I kill this ****? I'be tried, acetone, lacquer thinner, paint stripper, toilet cleaner, sanding, scrubbing with dish soap and hitting it with a Brillo pad and nothing's worked. What's the simple trick to this?
Thanks—
Thanks—
Received 3,043 Likes
St. Jude Donor '05
dont know what to say I hate that stuff
same goes for guys using a bug sprayer on the entire engine thinking it looks great. Turns into a ball of dust fast lol.
Good luck.
Good luck.
Yeah, agreed, obviously. Can't fathom why Armor-All of would be used on the seats? Who would want a slippery shinny seat when their driving at speed, through turns and switchbacks? The seats offer no lateral support as it is, why would you want to slide around between the console and door panel?
Nonsense !
Still waiting for that magic bullet here. Something as simple as, "I use laundry bleach." would be superb. Although, I just tried that as well and no luck.
Nonsense !
Team Evil (10-21-2017)
Received 2,878 Likes
Hi,
Lacquer thinner and then Simple Green.
Regards,
Alan
Regards,
Alan
Received 6,943 Likes
2015 C2 of Year Finalist
go to a auto body paint store and get silicone remover. MEK would help too. but I don't know what that will do for plastic
You wanna keep that $hit and other sprays like silicone, WD40, Liquid Wrench AS FAR AWAY FROM FIBERGLASS as possible. It'll wick up into the fiberglass and you'll BE IN REAL TROUBLE. Maybe not right away but sometime.
This can be bought at any auto paint store !
If your using a spray gun they also have an additive called fisheye remover that is added to the paint or dye that your spraying!
They also sell a product called Bulldog which is an adhesive sealer that should be sprayed before paint or dye ! Can be bought in a spray can if your not using a spray gun !
I've also found that by spraying in super lite coats letting each one dry you can sometimes build over what is causing the fisheye !
Hope all this helps!
There are different names for it but its function is wax and grease remover ! There are different strengths of it so start with the least strength of it!
Success ! Rubbing alcohol followed by window cleaner did the trick ! Thanks for all of the other tips, I'm going to keep them in my arsenal, probably grab some Prep-Sol as well next time that I'm at the paint jobbers.
Thank you, but I STILL hare Armor-All !
LenWoodruff (10-22-2017)
Nam Labrat
Received 4,174 Likes
Good info above!
So you are saying you'd like a gallon of Armor All for your birthday?
