WTF is up with my gas hole???
On my 69, we replaced my gas tank, and when we installed it as per the manual, the filler hole is not centered under the filler lid, it is pretty far to the back of the lid opening. I can still get the cap off and on, so I am thinking to leave it as it is. When we try to shim it up so it is more centered, there would be a few gallons I could not use and the gas gauge would not read correctly. It seems that the lip where the top and bottom of the tank are put together is hitting the body. We did compare the old tank to the new tank and they look identical. Honestly, I did not take a pic of the placement before, and I really do not remember what it looked like, so I am looking for some help. I did find and read a thread on this issue, but it did not seem to come to and definite conclusion. Please see the pic and let me know your thoughts. In my dimmest of memories, I kind of think it was kind of like this before, but I would like to hear from you.
you gas tank is not aligned property on the frame.
Bart K (11-06-2017)
Bart K (11-06-2017)
As Zwede stated you need to loosen or disconnect the straps and reposition the tank (rotate) so it sets correctly on the frame and cross member.
Bart K (11-06-2017)
We did try that, but it will not go any further forward. Next time I am there we will give it another try. Would anyone be willing to take a pic of under your filler lid and attach it on this thread so we can see what "correct" looks like????
Ok, we will take another look. So does that lip fit above the cross member and under the body? We put some shims between the gas tank and the straps and we can get the filler hole centered, but I do not want to leave the shims in place. From what you guys are saying, it should fit properly without any shimming. So we will take another look.
Received 2,878 Likes
Alan is correct. Your tank in the pic is not only sitting too far rearward but is slightly to the left of center. You can also move it side to side slightly to center it with the straps loose.
Bart K (11-06-2017)
On my '72 C3, I had a similar issue. I ultimately found out that someone sealed up the vent ports on the tank AND left a sealed gas cap on the tank. So the fuel pump sucked in the tank and deformed it badly due to the vacuum it created. Would never have thought this possible, but it did happen. I posted photos of this in another thread ("what did you do to your C3 today" thread, I think).
I was able to re-shape the tank to somewhat normal and re-installed it. The cap is now centered properly.
So take a look at your setup and make sure yours isn't messed up like mine was. Some PO's have no business working on cars.
Bart K (11-06-2017)
I appreciate that Chapter 2. The fuel tank is brand new. We have put some gas in the tank, but the car has not been run yet, so I am not thinking we have a deformed tank, but probably just slightly out of alignment. We will check it and see how it goes!
I have another request for you 69 owners if you would be willing. I would like the measurement from the rear window to the middle of the fill hole, and also a measurement from the rearward edge of the rear deck to the middle of the fill hole. If someone has a tank out, I would like the measurement from the rear of the tank to the back of the filler neck and from the front of the tank to the front of the filler neck.
I am trying to determine if any body work was done that may have created this situation, or if I have a defective new tank. I have a call in to my buddy Carl to see if he still has the old tank.....this is a frickin' nightmare.
Thanks in advance guys!
69 coupe
from the lower rear glass to the center of the fill hole - 26"
from the center of the fill hole to the rear deck lip edge - 19 5/8"
Bart K (03-13-2018)
I was going to say, in jest, take the body off and move it to where the fill hole is. But it looks like you're worried that that may have already happened with where the fill hole was.
Hi BK,
How about a couple of photos of the bottom of the tank's position on the rear crossmember and tank support bracket.
Isn't it likely that that's causing your tank filler neck/hole misalignment?
Regards,
Alan
1-1/8" to straight edge held against forward vertical wall of tank.
Regards,
Alan
Bart K (03-13-2018)
We will get to the bottom of it, and when we do, I will be sure to share the problem and the fix with you all.
Hi BK,
Regards,
Alan
Regards,
Alan
