Holiday Pay It Forward 2017
Dementer sole survivor
Received 6,278 Likes
2016 C3 of Year Finalist
tach drive with newer black cap and internals, red cap has been moded for finding TDC
header alternator bracket
HEI wroked fine when removed, I went back to the original style distributor with pertronix.
Header alternator bracket has been claimed
AllC34Me (11-19-2017)
Air Induction assembly
I have a working 73-75 air induction hood flapper assembly, will post pic once I get it dug out.
I don't have a C3 currently, just 2 C5s, so nothing here for me. But I did find in my stuff a $25 gift certificate for Van Steel while cleaning out my desk. I won it at a car show, the date on it is 03/28/2014, so no guarantees that they would still accept it. Up for anyone that can use it.
AllC34Me (11-20-2017)
have a few things...
left and right B pillar covers in 742 red from my 81.
weld on style clutch cross arm frame bracket
auto shift lever assembly
air intake plenum dual snorkel and brake pedal arm for an automatic
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
Great job explaining the guidelines David.....!!!
I'll search through my storage room.
I am sure I have a bunch of stuff available.
Merry Christmas to all us Christians and Happy Holidays to the rest of my CF brethen.
Dennis
Dennis
I have a working horn and a pair of under the seats, seat belt retractor covers from a 77 if anyone can use them.
AllC34Me (11-25-2017)
Senior Member
Received 2,031 Likes
St. Jude Donor '10
Thank you and best regards,
David
Least I can do and Happy Thanksgiving. John
AllC34Me (11-23-2017)
Senior Member
St. Jude Donor '10
HI David, will those halogen headlamps fit without any modification to the bucket?
Happy Thanksgiving
Scott
Happy Thanksgiving
Scott
Senior Member
St. Jude Donor '10
I don't know, I didn't get that far. Sorry.
#34
2017 C3 of the Year Finalist
St. Jude Donor '20- '21
Well my 72 corvette is relatively new to me!! But here is what I could dig up Not much but it may help someone out!!!!
Rear exhaust bezels. Not sure what was done to them probably pitted and painted but>>>>>>>>>>>
Weatherstripping for a 1972 window pillar drivers side. Brand new unused. Someone replaced one on my car and not the other. This is the drivers side. Let me know if any of theses can be of any help to anyone. Ike
AllC34Me (11-26-2017)
#35
I have a few more things to throw in...
1. Tire tub and V strap (not in the best shape but it works) - Local pick-up
2. Rear 9 leaf spring (aftermarket) - Prefer local pick-up
3. Set of 4 Goodyear tires (good tread but not sure how old they are) - Local pick-up
4. Radio (not sure if it works and tape flap is missing) not sure what year or aftermarket? CLAIMED AND SHIPPED!
5. 69' brake proportioning valve (I plugged it in and my light never came on, no guarantee if it's working properly, though I think so)
note: A few items I listed are large and I've marked for local pick-up.
2. Rear 9 leaf spring - Prefer local pick-up
3. Set of 4 Goodyear tires - Local pick-up
4. Radio CLAIMED AND SHIPPED!
#38
The other two housings came with some other parts. Not sure what year they fit. One is missing a mounting stud.
Adjustable strut rods. Bushing on one end is shot. Would be good to rebuild or use heim ends.
Rear shock mounts. Splines seem good, they worked when I had them installed. CLAIMED
Factory strut rods, needs bushings.
Two spring mount bolts.
Two trailing arm bolts
Strut rod mount with eccentrics.
Spring plate
Two e-brake frame mount brackets.
Bare trailing arm R/S.
Some e-brake hardware.
Heat shield under rear diff.
Two brake pad caliper pins.
E-brake cables, work free, with frame brackets.
Batwing for an 80-82.
Two halfshafts. Ujoints are ok, wouldn't hurt to replace them.
Attachment 48228791
Attachment 48228792
Spring plate
Attachment 48228791
Attachment 48228792
#39
#40
Nix sadly to far for me but that may help somebody else.
David about to PM you regarding those wheel trim pieces if they are still a available.
Thanks iIke
Thanks iIke
