header nose bar adhesive.
does anyone know the type of adhesive used to bond the reinforcement metal to the inside of the nose? i removed the old rotten one and need to place the new one in.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The header wasn't glued in place it was riveted to the front surround panel. You could use SEM 39747 but you'll need a special gun to use it... I'd just rivet the new header in place.
Willcox
Willcox
313hitman (12-03-2017)
I removed the rivets but had to use a heat gun and putty knife to separate it from the fiberglass. that is the only reason i assumed it was glued in some type of way from the factory. thank you for your response.
